Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
123 registered members (2015_PSD, 87sammy, 2010Civic, AdditiveOCD, 3311, 8 invisible), 1,805 guests, and 60 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
Honda gx390 governor falling back to 3200rpm? #4749931
05/07/18 07:56 AM
05/07/18 07:56 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
What causes the throttle control arm to not stay at 3600 rpm? I can manually move it all the way over and it will go to 4000 then let go and it will go to 3600 then slowly work it's way to 3200rpm no load, 2800rpm under load. This is a pressure washer with 9hrs on it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4749951
05/07/18 08:32 AM
05/07/18 08:32 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4750051
05/07/18 11:11 AM
05/07/18 11:11 AM
MN
Tman220 Offline
Tman220  Offline
MN
There is probably a nut you can tighten down that will increase the rotating friction of the throttle arm.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Honda gx390 governor falling back to 3200rpm? [Re: Tman220] #4750177
05/07/18 01:22 PM
05/07/18 01:22 PM
Houston, Texas
Houston, Texas
There is, but I'm not sure if that will affect how the governor operates. I guess the throttle lever is different than the governor arm. What causes it to change? It worked okay in the beginning afaik.
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4750846
05/08/18 07:30 AM
05/08/18 07:30 AM
USA
mk378 Offline
mk378  Offline
USA
The speed control lever is supposed to stay where you set it because of friction from the pivot nut. If it does not stay, tighten the nut. If it is too hard to move, loosen the nut. That will not affect anything else.
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4751644
05/08/18 10:30 PM
05/08/18 10:30 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
The spring controls your governed speed. Off chance the wrong spring was installed, or maybe the engine is supposed to run at 2800 RPM loaded.
Re: Honda gx390 governor falling back to 3200rpm? [Re: punisher] #4752651
05/10/18 07:23 AM
05/10/18 07:23 AM
Houston, Texas
Houston, Texas
[quote=punisher]The spring controls your governed speed. Off chance the wrong spring was installed, or maybe the engine is supposed to run at 2800 RPM loaded. [/quote
It ran at the correct rpm for a few hours atleast. I'll go ahead and tighten that nut and then maybe turn the stop screw in a little bit so it runs at 3600rpm and not 4000 when all the way against it.
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4753567
05/10/18 10:04 PM
05/10/18 10:04 PM
Houston, Texas
Houston, Texas
I tightened the nut. It stays in place now, haven't started it up yet though.
Re: Honda gx390 governor falling back to 3200rpm? [Re: motor_oil_madman] #4754812
05/12/18 07:50 AM
05/12/18 07:50 AM
Houston, Texas
Houston, Texas
Worked like a charm.
