Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
EV Future
by Danno. 01/17/19 08:11 AM
Sayings that people told you...
by Char Baby. 01/17/19 08:04 AM
Certified oils
by waltywalt. 01/17/19 07:55 AM
Favorite Movie Lines And Scenes
by billt460. 01/17/19 07:14 AM
Suzuki Jimny
by ridgerunner. 01/17/19 06:52 AM
Amsoil SSO 5w50
by Vspec. 01/17/19 06:36 AM
Dodge truck question - gear shift
by gfh77665. 01/17/19 06:22 AM
GAC may be coming to America?
by Char Baby. 01/17/19 06:03 AM
Another favorite video
by Char Baby. 01/17/19 04:59 AM
Detail a 2012 Kia Soul
by jerseyguy123. 01/17/19 02:23 AM
Can top end cleaners damage engine?
by avacado11. 01/17/19 01:40 AM
Where are Fram Oil and Air filters made ?
by rubberchicken. 01/17/19 12:42 AM
Based on these specs, which oil is better?
by SlavaB. 01/17/19 12:42 AM
Fram FPS9688 from ebay (Ultra XG9688)
by SlavaB. 01/16/19 11:12 PM
Pick my filter—
by lukejo. 01/16/19 10:41 PM
2007 Camry V6 feedback......
by kenwin30. 01/16/19 10:41 PM
Pioneer SW-8MK2 Subwoofer
by webfors. 01/16/19 10:39 PM
neiltt, Drspel, wwalrus, fedorqwe, Terand_1
66957 Registered Users
107 registered members (bbslider001, beanoil, Asterix, BearZDefect, ABerns, Ag76, 8 invisible), 1,860 guests, and 49 spiders.
Topics296,712
Posts4,957,417
Members66,957
Most Online2,577
Jan 14th, 2019
prius bleeding that hard? #4749738
05/06/18 09:06 PM
05/06/18 09:06 PM
Chicago
bowlofturtle Offline OP
Chicago
I might be tasked to do one on a 2nd gen prius. Seems like its a bit of a mixture of people having tons of issues and no issues.
Hardware looks exactly the same, if i disconnect the battery brakes shouldn't try to activate and i can normally 2 man bleed after right?
Or so i really have to stomp on the pedal 8 times and etc.
Toyotas have radio codes like honda?
My toys
-05 Infiniti G35x 121k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 7k
-98 Nissan Maxima 145k
-09 Toyota Camry V6 86k
Re: prius bleeding that hard? [Re: bowlofturtle] #4749754
05/06/18 09:30 PM
05/06/18 09:30 PM
Chicago
Jooksing Offline
Jooksing  Offline
Chicago
If it is the same as my Rx hybrid, you should use the toyota techstream cable and software. The brakes is controlled by electric pumps. The procedure is to pull the abs fuse for the front, the software then pumps the fluid out. The rear brakes was done like a normal car. Some reported the brake pumpnmay fail in the RX after a flush. ($3000 for the pump)
Check the Prius forums for specifics.
Re: prius bleeding that hard? [Re: bowlofturtle] #4749814
05/06/18 11:41 PM
05/06/18 11:41 PM
CA
The Critic Offline
The Critic  Offline
CA
It is not difficult if you have Techstream or a decent aftermarket scanner such as the Autel Maxisys Elite that I have. Otherwise, without proper tooling, I HiGHLY recommend that you leave it alone. The brake pedal is actually a brake by wire setup.
Also, many Gen 2 Prius have issues with the ABS modulator assembly. There was a warranty extension on them, but I believe it has expired.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: prius bleeding that hard? [Re: bowlofturtle] #4749828
05/07/18 12:45 AM
05/07/18 12:45 AM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
The service manual describes in detail how to bleed brakes either using Techstream, or without it. For the latter, essentially, you put the system in "Invalid Mode," bleed the rears by letting the pump push fluid out, and bleed the fronts more or less conventionally by the two-person method. I was afraid of getting in trouble and let the dealer change my brake fluid ($110-$20 service coupon=$90).
2011 Toyota Prius now at 95K
Re: prius bleeding that hard? [Re: The Critic] #4751624
05/08/18 08:46 PM
05/08/18 08:46 PM
Chicago
Chicago
If i get my hands on a techstream is it as simple as follow the prompts
My toys
Maintaining
-16 Jetta 1.4T 7k
Re: prius bleeding that hard? [Re: bowlofturtle] #4751632
05/08/18 09:01 PM
05/08/18 09:01 PM
USA
slacktide_bitog Offline
USA
You need a scanner to bleed the brakes, in a Toyota? mad crzy
Too bad you can't just use speed bleeders and bleed like regular brakes smile
Re: prius bleeding that hard? [Re: bowlofturtle] #4752538
05/09/18 10:53 PM
05/09/18 10:53 PM
CA
The Critic Offline
The Critic  Offline
CA
Yes, but you will need 2 people.
Many aftermarket tools will do the air bleed function. You do not need to use a techstream.
