Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
134 registered members (AdRock, 28oz, 92saturnsl2, 97prizm, AdditiveOCD, 17 invisible), 1,956 guests, and 31 spiders.
Topics296,609
Posts4,955,776
Members66,950
Most Online2,577
Jan 14th, 2019
avalanche spare tire carrier mod #4749613
05/06/18 07:15 PM
05/06/18 07:15 PM
out there
spasm3 Online content OP
spasm3  Online Content OP
out there
If any of you with gm trucks have not removed your spare, you may be in for a surprise.
My spare would lower only about 4 inches and the cable would drop but the tire would not drop down. Gm has a hook on a lever as a secondary retainer to the cable hoist. The hook does not always release and you will have to remove the license plate and either use a really long screwdriver and a hammer to release the tire or buy gm's release tool. Add some rust and it ain't coming down when you need it.
I modified mine so that you can always get the tire down. I notched the retainer ring, so it still will retain the hook on the cable, but you can spin the tire and the hook will clear the notch for the tire to drop. When you load the spare, just index the hook on the cable with some white paint on the tread and make sure it does not line up with the notch when the hoist is tight. That way the tire is still held in if the cable fails.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: avalanche spare tire carrier mod [Re: spasm3] #4749702
05/06/18 08:32 PM
05/06/18 08:32 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
I own a 2005 Avalanche and should do a dry run on on this just in case. I’ve never even looked at my jack or tool kit but shouldn’t the release tool be in the kit?
Re: avalanche spare tire carrier mod [Re: gman2304] #4749705
05/06/18 08:36 PM
05/06/18 08:36 PM
out there
out there
The kit contains a tire iron and square tube that will be used to winch down the tire. The problem is when the winch lowers but the carrier hook remains on the lip. i had to use my long serpentine belt wrench to knock it in. No about of shaking or wiggling would let the tire drop.
This is the gm tool for stuck tires. A super long screw driver is less.
https://www.amazon.com/STUCK-SPARE-TIRE-RELEASE-THX-805/dp/B00YTNFGG2
Re: avalanche spare tire carrier mod [Re: spasm3] #4749722
05/06/18 08:51 PM
05/06/18 08:51 PM
out there
out there
Better picture of the hook.
Re: avalanche spare tire carrier mod [Re: spasm3] #4749743
05/06/18 09:12 PM
05/06/18 09:12 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
Hoo hoo. I have NEVER taken the spare down in my 09 Suburban. Thanks for the tip.
Re: avalanche spare tire carrier mod [Re: spasm3] #4749834
05/07/18 01:46 AM
05/07/18 01:46 AM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
My 02 does not have that setup when I heard the horror stories of other owners unable to lower their spares.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: avalanche spare tire carrier mod [Re: Kibitoshin] #4749895
05/07/18 05:35 AM
05/07/18 05:35 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
No hijack here...just another spare tire lowering caveat...this time for Fords
I had a Ford where the spare's hanger was a chain. Cranking the gearbox lowered the chain which had a round plate which went through the wheel's center hole.
Rust would form and fuse links of the chain solidly. This stopped the chain from running.
A little banging would free it up. Then I lubed it up well.
Regarding the OP: What was the mod? Isn't indexing the hook so it goes through its notch the way it works in the first place?
Re: avalanche spare tire carrier mod [Re: Kira] #4749925
05/07/18 06:29 AM
05/07/18 06:29 AM
out there
out there
There was no notch, I created the notch with a jigsaw.
Re: avalanche spare tire carrier mod [Re: spasm3] #4749930
05/07/18 06:52 AM
05/07/18 06:52 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Mine was so corroded nothing but cutting the cable and starting over worked. So I gave up and had the dealer install a new one while I was there for another issue. First thing I did when I got home was test. There was no secondary lock! So if the dealer is doing that, there must be a TSB somewhere. Because they replaced, I don't have a part number. If you want I'm working from home today, I can drop the wheel and take a couple pics of it. Wasn't that expensive.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: avalanche spare tire carrier mod [Re: spasm3] #4758239
05/15/18 07:44 PM
05/15/18 07:44 PM
out there
out there
Got a new spare from the pullit yard. Installed it and checked it. When i spin it around the notch works perfectly.
