Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
49 registered members (10WSmuckers, bdcardinal, AZjeff, A310, 4WD, Black_Thunder, 2 invisible), 1,641 guests, and 35 spiders.
Topics300,480
Posts5,176,838
Members70,514
Page 1 of 6 1 2 6
Rislone Clean Oil Analysis #474874 03/10/03 07:00 PM
MolaKule Offline OP
Global Moderator
Global Moderator
As promised here is the analysis for Rislone.
Oil Brand/Weight : Rislone additive
Type Equipment : clean oil
Miles/Hours on oil : clean
Total Miles/Hours : clean
Results ppm/% Comments (blank=normal)
Wear
Copper 0
Iron 0
Chromium 0
Lead 0
Aluminum 0
Silicon 1
Tin 0
Additives
Molybdenum 0
Sodium 0
Magnesium 0
Zinc 380
Potassium 0
Phosphorus 352
Calcium 768
Physical Properties
Water negative
Sulfur na
TBN 5
[email protected] C (cSt) 9.2 SAE 20w
TAN 0.5
This is the Rislone "Add at Oil Change" additive found in the Yellow bottle, and cost's approx. $2.29 at Walmart. The oil is dyed blue/green. As you can see it is nothing more than a 20 weight mineral oil with very low levels of calcium detergent, some anti-foam, and very low levels of ZDDP, about 1/4 to 1/5 of the level you would find in an SL formulated motor oil. The level of detergent is too low to really affect cleaning. Any "run-of-the-mill" OTC motor oil will contain much more detergent than this brew.
Advantages to using this OTC additive? None whatsoever.
Disadvantages: 1.) Cost. In my view it should cost less than Walmart's Oil Additive in the blue bottle ($.78), since Rislone contains less ZDDP. 2.) Thinning of the crankcase oil. If I had an engine spected to run 30 weight oil this additive would thin it down. Testing revealed no viscosity index improvers (VII's) to keep the oil from thinning down.
Re: Rislone Clean Oil Analysis #474875 03/10/03 07:04 PM
P
Patman Offline
Global Moderator
Global Moderator
P
Very interesting, thanks for posting it!
(I moved this to the virgin samples section for you)
Re: Rislone Clean Oil Analysis #474876 03/13/03 05:47 AM
G
GROUCHO MARX Offline
G
Molakule, thanks for the info. Down the road, I might try to get my hands on some Neutra and run a VOA.
[ March 13, 2003, 09:48 PM: Message edited by: GROUCHO MARX ]
Re: Rislone Clean Oil Analysis #474877 03/13/03 05:54 PM
J
jason07-1zzfe Offline
J
Neutra uses esters to clean, that won't show on a VOA
Re: Rislone Clean Oil Analysis #474878 03/13/03 06:04 PM
P
Patman Offline
Global Moderator
Global Moderator
P
quote:
Chances are pretty good that Rislone won't be using much, if any esters in their $2 product though.
Re: Rislone Clean Oil Analysis #474879 03/13/03 06:23 PM
J
J
True, I doubt they do. Maybe they use some solvents to clean? That wouldn't show either. Is that possible.
But I also meant that for Groucho to do a VOA on Neutra would probably be pointless as it would show up pretty much blank. And we know why already.
Re: Rislone Clean Oil Analysis #474880 03/14/03 06:38 PM
G
G
Thanks Jason,
i guess then that it was pointless to do a VOA on Rislone?
We assume no esters, but we don't know.
Re: Rislone Clean Oil Analysis #474881 03/15/03 12:05 AM
MolaKule Offline OP
Global Moderator
Global Moderator
There are certain chemicals one can use to test for esters as the esters will agglomerate to the wall of a beaker when these chemicals are added to an oil.
No esters were found in Rislone, and Rislone makes no declarations about there being any in their products.
I ran these tests on Rislone and CD2 at the request of a number of people on the board who wanted to see if there were any real economic or mechanical benefits to some of these OTC additives.
Re: Rislone Clean Oil Analysis #474882 03/17/03 06:56 AM
G
G
Kudos to you Molakule, it's a valuable report. I hope to contribute more soon, hence my idea about neutra.
Re: Rislone Clean Oil Analysis #474883 03/17/03 07:30 PM
boxcartommie22 Offline
molakule, could you do a sample on synergyn's oil treatment?
Re: Rislone Clean Oil Analysis #474884 03/21/03 02:55 AM
csandste Offline
I sent the VOA to Rislone and got a response from one of their VP's with (hopefully) a promise of another response from their tribologist.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=000366;p=1#000000
Re: Rislone Clean Oil Analysis #474885 03/24/03 12:09 AM
csandste Offline
Their tribologist responded(posted in additives section), not a lot of detail though. Wish someone more knowledgable than me could tell me if there's anything to their points--
1. That the product is different when mixed with oil than a stand alone product.
2. That some of the factors don't show up in testing.
Re: Rislone Clean Oil Analysis #474886 03/24/03 03:44 AM
MolaKule Offline OP
Global Moderator
Global Moderator
Re: Rislone Clean Oil Analysis #474887 05/06/03 12:54 AM
U
unDummy Offline
U
Re: Rislone Clean Oil Analysis #474888 05/12/03 09:49 PM
MolaKule Offline OP
Global Moderator
Global Moderator
And this means......?
Page 1 of 6 1 2 6
