Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 13 invisible), 2,038 guests, and 180 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
Wheel cleaner #4748525
05/05/18 03:10 PM
05/05/18 03:10 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Does anyone use a wheel cleaner that actually dissolves brake dust and cleans well? Everything I have found has left me disappointed as I might as well just use the car wash soap and wheel brush as I would get the same results.
Re: Wheel cleaner [Re: 007] #4748533
05/05/18 03:25 PM
05/05/18 03:25 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Sonax Full Effect.
Meguiar's Wheel Brightener.
"Zed's dead baby, Zed's dead."
Wheel cleaner #4748534
05/05/18 03:26 PM
05/05/18 03:26 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Re: Wheel cleaner [Re: 007] #4748535
05/05/18 03:27 PM
05/05/18 03:27 PM
Clermont, Fl
007 Offline OP
007  Offline OP
Clermont, Fl
Moved to the detail section. Sorry
Re: Wheel cleaner [Re: 007] #4748539
05/05/18 03:34 PM
05/05/18 03:34 PM
North Carolina
North Carolina
Sonax Full Effect.
Re: Wheel cleaner [Re: rooflessVW] #4748540
05/05/18 03:39 PM
05/05/18 03:39 PM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
Ditto on the Meguiar's. It is an acid based cleaner, so you have to be careful. Don't let the subtle grape scent fool you, it will knock you down. That said it cleans really well and at a 4:1 ratio is cost effective. Heavily soiled wheels will still require agitation, but light duty spray on and hit it with the power washer. Once you get the wheels clean if you keep up cleanings you can use a normal degreaser.
'17 VW GTI 2.0T - 6MT - 14K - PPE 5w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 159K - PP 10w30
Re: Wheel cleaner [Re: 007] #4748542
05/05/18 03:42 PM
05/05/18 03:42 PM
Texas
JBinTX30 Offline
JBinTX30  Offline
Texas
Meguiars Super Degreaser if you need a lot and want more pro product. Superclean, and Meguiar's Ultimate Wheel Cleaner (which is made to remove ferrous metals and works great on paint to remove them as well)
05 GMC Yukon XL SLT 5.3 CE 5w30 51042
06 Chevy Trailblazer LS 4.2 PP 5w30 XG9837
Re: Wheel cleaner [Re: 007] #4748558
05/05/18 04:00 PM
05/05/18 04:00 PM
Tn.
CourierDriver Offline
Tn.
what ever they put in a the car wash....
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: Wheel cleaner [Re: 007] #4748573
05/05/18 04:16 PM
05/05/18 04:16 PM
USA
E365 Offline
E365  Offline
USA
Surf City Code Red at NAPA. It’s one of those color changing ones as a chemical reaction takes place. I mostly just use a brush and soap though.
Whatever’s on sale...
Re: Wheel cleaner [Re: 007] #4748618
05/05/18 05:33 PM
05/05/18 05:33 PM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
Eagle One around here in Kentucky
Don't waste your time on a slipshod repair.
Re: Wheel cleaner [Re: rooflessVW] #4748634
05/05/18 05:58 PM
05/05/18 05:58 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Sonax Full Effect.
+1 on the Sonax. It's not cheap though. I bought a 5 liter jugs at the Toronto auto show and split it into 4 with 3 co-workers (was $100 cdn for 5 liters) you get less for $22 from Amazon.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Wheel cleaner [Re: rooflessVW] #4748652
05/05/18 06:29 PM
05/05/18 06:29 PM
PimTac Offline
PimTac  Offline
Sonax Full Effect.
Dittos on the Sonax.
Cannot see signatures any longer so it doesn’t matter.
Re: Wheel cleaner [Re: 007] #4748665
05/05/18 06:52 PM
05/05/18 06:52 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
I used to be a simple green user for years. It seems to have lost its bite as of late. Switched to Meguiars all wheel cleaner $4 from Walmart and it does what simple green used to do. Spray it on, foam turns muddy looking shortly after. Slight brushing and my white letters are white again.
No complaints.
Re: Wheel cleaner [Re: 007] #4748842
05/05/18 10:02 PM
05/05/18 10:02 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Not sure what brake pads people use, but Ive sort of resolved to not buy wheel cleaner again.
For everything from high bite-high dust euro pads to the cleanest ceramics, the residues generally come right off. On the euro pads, the dust cleans off super-easy, but there can be some small bits of black dirt embedded. Ive not found any cleaner to be particularly effective.
Ive run the color changing stuff, and it too doesn't do much. It will change color near the caliper, as will overspray on the disc, but the dust on the wheel? Not much of anything.
Ive taken to using wheel woolies, which work great most of the time, and I use soap from the bucket. I rinse my tools constantly, so the soap bucket stays clean and grit free.
Sometimes Ive used meguiars wash and wax (waterless wash, it's a white translucent product) on the wheels, as I figure the waterless wash (though I'm not using it that way) helps lift and lubricate particles, and the wax helps protect/seal the surface. If Im going to spray the car with HydrO2, then the wheels just get soapy water from the bucket, but get that treatment along with the rest of the car.
Re: Wheel cleaner [Re: 007] #4752005
05/09/18 12:46 PM
05/09/18 12:46 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Modern ceramic pads have 99% negated the point of dedicated wheel cleaners for me...
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
