Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Towkid, denor, Jubaxtreme, CAJ1966, Shiza
70550 Registered Users
96 registered members (Ag76, 14Accent, AlaskaMike, 01rangerxl, 1978elcamino, 53' Stude, 5 invisible), 3,064 guests, and 17 spiders.
Topics300,673
Posts5,180,884
Members70,550
Lucas Marine Grease Formula Change #4748115 05/04/18 09:29 PM
R
racerdude321 Offline OP
R
Hi All,
Great forum, I've lurked for awhile but just now joined up.
I've been using Lucas Marine grease as my go-to for years. I use it in everything from my Volvo boat outdrive, Craftsman riding lawn mower spindles, Dexter EZ-lube trailer wheel bearings, to my New Holland tractor backhoe pins, etc. I went to grab a new tube today and noticed that is was now an OBCS (Overbased Calcium Sulfonate) rather than the lithium-complex I've been used to using. I'm worried because the 4 ball wear and the timken load lb ratings have gone down. Will it be okay for the shock loads in the backhoe pins and boat outdrive anymore?
So should I use the new formula or should I look into a different grease? Or am I overthinking it? I'd really like to continue using just one grease for everything.
Current Tech Sheet:
https://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Wayback showing the old Tech Sheet as of 2/2/18:
https://web.archive.org/web/20160413034512/http://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Thank you.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748135 05/04/18 10:02 PM
MolaKule Offline
Global Moderator
Global Moderator
Nope, the OBCS/polymer greases are the big deal today.
Amsoil uses a similar formula.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748236 05/05/18 06:03 AM
N
njohnson Offline
N
In the case of the Timken load lb rating, higher is better. For the 4 ball wear number, lower is better. It means the wear scar being produced is lower. I think that is the way the numbers work. I could be wrong.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4784986 06/12/18 02:27 PM
M
monster1 Offline
M
It's been this new calcium based formula for at least a few years now as that's the stuff I bought a few years ago when I replaced an axle with a damaged spindle.
