Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
Ford Motorcraft FL-820S Cut Open
by ThirdeYe - 09/18/19 07:12 PM
AC Delco PF47E cut open
by ThirdeYe - 09/18/19 07:07 PM
JDubyah, 05SentraRed, TSpinner, bbrown, Firemedic15
69326 Registered Users
83 registered members (97prizm, ATex7239, 4WD, 53' Stude, Andrei, atikovi, 11 invisible), 1,301 guests, and 25 spiders.
Topics294,764
Posts5,066,121
Members69,326
Most Online3,532
Jul 30th, 2019
Lucas Marine Grease Formula Change #4748115 05/04/18 10:29 PM
R
racerdude321 Offline OP
R
Hi All,
Great forum, I've lurked for awhile but just now joined up.
I've been using Lucas Marine grease as my go-to for years. I use it in everything from my Volvo boat outdrive, Craftsman riding lawn mower spindles, Dexter EZ-lube trailer wheel bearings, to my New Holland tractor backhoe pins, etc. I went to grab a new tube today and noticed that is was now an OBCS (Overbased Calcium Sulfonate) rather than the lithium-complex I've been used to using. I'm worried because the 4 ball wear and the timken load lb ratings have gone down. Will it be okay for the shock loads in the backhoe pins and boat outdrive anymore?
So should I use the new formula or should I look into a different grease? Or am I overthinking it? I'd really like to continue using just one grease for everything.
Current Tech Sheet:
https://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Wayback showing the old Tech Sheet as of 2/2/18:
https://web.archive.org/web/20160413034512/http://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Thank you.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748135 05/04/18 11:02 PM
MolaKule Offline
Global Moderator
Global Moderator
Nope, the OBCS/polymer greases are the big deal today.
Amsoil uses a similar formula.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748236 05/05/18 07:03 AM
N
njohnson Offline
N
In the case of the Timken load lb rating, higher is better. For the 4 ball wear number, lower is better. It means the wear scar being produced is lower. I think that is the way the numbers work. I could be wrong.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4784986 06/12/18 03:27 PM
M
monster1 Offline
M
It's been this new calcium based formula for at least a few years now as that's the stuff I bought a few years ago when I replaced an axle with a damaged spindle.
