Originally Posted By: Whimsey
I can honestly say that with our 2017 Explorer 2.3 EB the "engine noise" is the same using the factory fill, dealer first bulk oil change, my using Mobil 1 5W-30 and my use of Motorcraft 5W-30. It still sounds like a sewing machine when standing outside of it. Inside it's super quiet
. The 2 UOA's I did with the Mobil1 5W-30 and the Motorcraft 5W-30 showed good good wear numbers.
Though the Motorcraft 5W-30 did reduce in viscosity to a 20 weight in 4,275 miles while the Mobil 1 5W-30 just maintained it's 30 weight in 7,000 miles.
Whimsey
I've seen quite a few UOAs that show Motorcraft shears down quite a bit, and also Mobil 1 seems to shear down quite a bit too in some engines with lots of timing chains. I'd think that as the miles get put on the oil and it shears down in viscosity, then the engine may become somewhat more mechanically noisy. Changing the oil would then quiet up the engine again if the noise was viscosity related.
Thanks for your feedback. If the Motorcraft 5W-30 oil shears well into a 20 wt in as little as 4,275 miles how does Ford expect the oil to go 10,000 miles/1year on that oil in the turbo DI engine that spec's 5W-30? What would the viscosity be at 10,000 miles when your iOLM says it's time to change it? It's not comforting if you plan on keeping your vehicle for a long time.
Whimsey
Good question ... and who knows. But if you look at the collection of UOAs in this thread you can see how Motorcraft and Mobil 1 have sheared down compared to some other oils. Makes me wonder too, but I guess if motors live on xW-20 then they'll still survive if a 5W-30 shears down to a 20. What about 5W-20 ... shear down to a 16 or less?
https://www.svtperformance.com/forums/threads/official-gt-5-0-boss-302-uoa-thread.805918/
