Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
115 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 11 invisible), 2,033 guests, and 182 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
New to me 07 Chevy Suburban what do I need to know #4746987
05/03/18 06:29 PM
05/03/18 06:29 PM
ct
will1780 Offline OP
will1780  Offline OP
ct
First time Chevy owner. 07 Suburban LT 5.3
Purchased at auction with 167k on the clock. Hear a lifter tick for sure and the CEL code is for an evap leak. First thing on agenda is the lifter tick, complete tune up, CEL and detail. Anything else I should keep An eye on with these suvís?
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4746999
05/03/18 06:42 PM
05/03/18 06:42 PM
Southwestern Alberta
Warlord Offline
Warlord  Offline
Does it have the cylinder deactivation system? If so a lot of people deactivate it as it was known to cause problems in the early years.
07 GMC Canyon - 204km
01 Saturn SL2 - 240km
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747007
05/03/18 06:49 PM
05/03/18 06:49 PM
out there
spasm3 Offline
spasm3  Offline
out there
I think the purge valve can be a common problem. The fuel cap can also cause this.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747051
05/03/18 07:51 PM
05/03/18 07:51 PM
Iowa, United States
KMJ1992 Offline
KMJ1992  Offline
Iowa, United States
Well, ive work on a couple avalanches, 1500s,and escalades we sold used. Not sure how much they all share but i think quite a bit. Those models i have replaced an evap canister, replaced failed catylitic converters, replaced an exhaust manifold that cracked. Replaced failed airride on an escalade. These are higher mileage rigs, 120k-180k. Other than that just usual higher mileage front end stuff like balljoints, swaybar links, and tierod ends that any vehicle needs eventually.
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747153
05/03/18 09:35 PM
05/03/18 09:35 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
07 is early DOD technology and there were some problems with it. It can be deactivated or removed completely. Synthetic oil and conservative OCIs seem to be the best bet to avoid dead cylinders. Do you know it's maintenance history?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: New to me 07 Chevy Suburban what do I need to know [Re: AZjeff] #4747158
05/03/18 09:40 PM
05/03/18 09:40 PM
ct
will1780 Offline OP
will1780  Offline OP
ct
Unfortunately I do not. Picked it up at an auction today
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747247
05/04/18 02:39 AM
05/04/18 02:39 AM
OKLAHOMA
GMguy84 Offline
GMguy84  Offline
OKLAHOMA
Here's a good site that i'm on. And I have a 01 Suburban 1500 myself and LOVE IT !! Been all over US with it and not major issues. Just turned 250K other week smile
http://www.tahoeyukonforum.com/
Dave
05 Silverado Z71 5.3 Mobil 1 EP 10W30/FUG XG3675
01 Suburban 5.3 Mobil 1 AP 5W30/FUG XG3675
1982 TRANS AM (KITT) Mobil S5K 10W40/M1-302A
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747251
05/04/18 03:20 AM
05/04/18 03:20 AM
FL
mcrn Offline
mcrn  Offline
FL
Drain and fill the tranny several times
2012 Nissan Rogue
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747349
05/04/18 07:59 AM
05/04/18 07:59 AM
Minnesota
Huie83 Online content
Huie83  Online Content
Minnesota
2007.5 was the first year of the cylinder deactivation/AFM in the 5.3. Like others have said, it can be problematic. If you already have a lifter tick it could be one of your DOD lifters failing. Run some MMO through it before the next oil change and switch to a high quality oil like PYB, Castrol or one of the other oils that is known to clean well.
If that doesn't help then I guess drive it until it really starts to make noise.They tap really loud whe they go fully bad. Then get ready for a expensive repair, the heads have to be pulled to replace the AFM/DOD lifters.
I have been looking for a new to me truck and did tons of research on this motor when looking at Silverado's and Sierra's. If you disable the DOD/AFM from the get-go usually it's not a issue. If it's already making noise its usually too late.
Could be something else all together too like a exhaust leak etc, just wanted to pass along what I found in my research on these recently.
Best of luck, keep us posted.
Re: New to me 07 Chevy Suburban what do I need to know [Re: mcrn] #4747361
05/04/18 08:10 AM
05/04/18 08:10 AM
wv
krismoriah72 Offline
wv
lifter tick/piston slap they all do it..at some point..just get used to it.
evap code http://www.gmtruckclub.com/forum/threads...cuit-low.18964/
tuneup- as soon as i pulled a wire to check the condition of the spark plugs the wire broke...so with yours being probably 10 years old plan on plugs and wires unless someone has done it. I went with NGK plugs.
fuel filter- take a peek at it..its probably oem so change it.
rear diff fluid- may or may not ever been changed
trans fluid- maxlife atf
throttle body- pull off front intake hose if its black and oily you can clean it.
brake lines- look along the frame rails- if they are rusty plan on changing them- mine blew on me.
Re: New to me 07 Chevy Suburban what do I need to know [Re: krismoriah72] #4747544
05/04/18 11:47 AM
05/04/18 11:47 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Possibly so but earlier than 07 won't lead to DOD lifter failure.
A guy at work has an 08 5.3 and he ignores maintenance and gets oil changed whenever at whatever quicky place is handy and it makes no noise so you're not necessarily destined for a failure. www.silveradosierra.com forum has lots of discussion about it.
Good truck, best of luck with it.
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747809
05/04/18 05:06 PM
05/04/18 05:06 PM
ct
will1780 Offline OP
will1780  Offline OP
ct
Is disabling the DOD/AFM difficult to do? Iím going to YouTube it to get an idea but Iím not sure Iíll be mechanically inclined if itís a big job
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747832
05/04/18 05:24 PM
05/04/18 05:24 PM
ct
will1780 Offline OP
will1780  Offline OP
ct
Also, wouldnít I feel it going from 4 cyl to 8 cyl via shuddering, upshot or downshifting? Nothing on my dashboard shows me anything about going from 4 cyl to 6 or 8 cyl. Iíve only driven it about 20 miles or so due to getting late yesterday and having to work all day today. I wonít be able to really see whatís going on with AFM till tomorrow. Thanks to all that have replied !!!
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747876
05/04/18 06:28 PM
05/04/18 06:28 PM
ct
will1780 Offline OP
will1780  Offline OP
ct
Re: New to me 07 Chevy Suburban what do I need to know [Re: will1780] #4747900
05/04/18 06:51 PM
05/04/18 06:51 PM
Denver
marine65 Offline
marine65  Offline
Denver
I think you need to know where the cheapest gas is.
2018 Hyundai Elantra GT
yup got two of them.
