NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
101 registered members (4WD, advocate, 69Torino, 53' Stude, 69GTX, A310, 13 invisible), 1,784 guests, and 42 spiders.
Topics296,896
Posts4,961,146
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
1992 Honda Accord just replaces timing belt now ha #4746793
05/03/18 02:24 PM
05/03/18 02:24 PM
North Carolina, USA
taztheman Offline OP
North Carolina, USA
I just replaced my timing belt at my school autoshop and on the drive home it overheated and the car is hesitating more than usual. Any help?
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746795
05/03/18 02:27 PM
05/03/18 02:27 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Taking a wild guess here but I'd say it wasn't installed correctly.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746796
05/03/18 02:31 PM
05/03/18 02:31 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Is the check engine light on?
Did you do the water pump as well?
If not did you check the bearing of the water pump to make sure it rotates smoothly?
Another question what belt did you use and was the writing on the belt facing outwards?
Did you check the timing marks of the new belt before rotating the crank by hand 720 degrees?
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746797
05/03/18 02:32 PM
05/03/18 02:32 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Timing belt change usually involves a water pump change right? So the high school shop students had to drain the coolant?
Did you refill the coolant and burp out any air?
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746803
05/03/18 02:38 PM
05/03/18 02:38 PM
North Carolina, USA
North Carolina, USA
The water pump had already been replaced a year or two before so I didnít bother doing it. And there are no check engine lights on. We put the timing marks in time and the lettering for the belt is outward.
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746805
05/03/18 02:39 PM
05/03/18 02:39 PM
North Carolina, USA
North Carolina, USA
Waterpump bearing felt fine.
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746806
05/03/18 02:39 PM
05/03/18 02:39 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Honda oem belt I hope?
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746809
05/03/18 02:41 PM
05/03/18 02:41 PM
North Carolina, USA
North Carolina, USA
No, I couldnít get one, itís a belt from napa
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746811
05/03/18 02:44 PM
05/03/18 02:44 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
TB tensioner ? and belt skip a tooth.
CX5 Touring 2.5L :-)
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746822
05/03/18 02:49 PM
05/03/18 02:49 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
+1 for a skipped tooth .
That's what happened on my 97' Accord .
Felt like the cat converter was stopped up.
Hesitated to rev over 5k rpms.
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746832
05/03/18 02:58 PM
05/03/18 02:58 PM
North Carolina, USA
North Carolina, USA
Thatís what I think happened. Iím towing it to my mechanic before I mess anything else up.
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746839
05/03/18 03:03 PM
05/03/18 03:03 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
How does just skipping a tooth cause it to overheat? If the water pump was operating properly prior to the timing belt change and the engine is now overheating, then the belt was not installed properly (routed correctly). I don't see how you overheat from the timing being off by one tooth.
Does that engine have balance shafts and a second belt?
1994 BMW 530i, 241K
Re: 1992 Honda Accord just replaces timing belt now ha [Re: kschachn] #4746865
05/03/18 03:23 PM
05/03/18 03:23 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Originally Posted By: kschachn
How does just skipping a tooth cause it to heat up? If the water pump was operating properly prior to the timing belt change and the engine is now overheating, then the belt was not installed properly (routed correctly). I don't see how you overheat from the timing being off by one tooth.
This, maybe air in the system. Honda can be very picky with air. Burp the system, check if both upper and lower hoses are getting warm/coolant level is good and t-stat is operating properly?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: 1992 Honda Accord just replaces timing belt now ha [Re: maverickfhs] #4746871
05/03/18 03:28 PM
05/03/18 03:28 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Well he indicated the pump was not replaced and didn't say they drained the coolant, so I assumed that wasn't the issue.
1994 BMW 530i, 241K
Re: 1992 Honda Accord just replaces timing belt now ha [Re: taztheman] #4746991
05/03/18 05:33 PM
05/03/18 05:33 PM
JC1 Offline
JC1  Offline
Did you install the belt or you were there for the whole install process? No students able to mess the install while you stepped away for a bit? Maybe the belt was threaded on incorrectly around the water pump?
Page 1 of 3 1 2 3
