Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
98 registered members (69Torino, 4WD, 1.8Tango, 97prizm, 53' Stude, 13 invisible), 1,781 guests, and 42 spiders.
Topics296,895
Posts4,961,137
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
2009 F150 5.4 3 Valve Engine Seized #4744712
05/01/18 04:11 PM
05/01/18 04:11 PM
Houston
PReal Offline OP
PReal  Offline OP
Houston
164k religious 5k oil changes with full synthetic.
Was driving today and suddenly engine locked up. No drop in oil pressure, plenty of oil on the dipstick,no overheating. No check engine lights no nothing until it locked up while diving then the low oil pressure light flickered. No crazy ticking, no loss in power. Just sudden engine seizure. Took the belt off, didnít help, pulled 3 plugs, no change.
Starter tries to kick over the engine and it rocks in the engine bay. Got it towed to a local rebuilder that has done 5.4 3vís in the last week. This truck has literally never had a problem outside of a wheel bearing!
What gives?
2009 F150 5.4
2008 Yukon 5.3
1996 F150 4.9 M5OD
1966 Ranchero 289 T5
1965 Mustang 306 T5
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744716
05/01/18 04:14 PM
05/01/18 04:14 PM
VA
thastinger Offline
thastinger  Offline
VA
broken timing chain prolly that is now bound up somewhere, was it ticking before?
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744718
05/01/18 04:19 PM
05/01/18 04:19 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Long shot guess would be timing chain also.
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744740
05/01/18 04:45 PM
05/01/18 04:45 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
It would be nice if you shared more info about the oil, like weights and brands.
1997 Maxima 195k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 196k, VWB 5w20 + SSS 10w40, MGL4967
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744746
05/01/18 04:52 PM
05/01/18 04:52 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Don't worry, just use PYB
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744754
05/01/18 05:01 PM
05/01/18 05:01 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Pull all 8 spark plugs! Pulling 3 random ones doesn't mean much.
2001 Chevy Camaro L92/4L80E
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744776
05/01/18 05:28 PM
05/01/18 05:28 PM
Houston
PReal Offline OP
PReal  Offline OP
Houston
Already at the shop. Itís had a steady dose of castrol, pennzoil, or mobil 1.
Typically 0w20, 5w20 or 0w30.
2009 F150 5.4
2008 Yukon 5.3
1996 F150 4.9 M5OD
1965 Mustang 306 T5
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744777
05/01/18 05:28 PM
05/01/18 05:28 PM
Houston
PReal Offline OP
PReal  Offline OP
Houston
2009 F150 5.4
2008 Yukon 5.3
1996 F150 4.9 M5OD
1965 Mustang 306 T5
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744793
05/01/18 05:44 PM
05/01/18 05:44 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
popcorn
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744814
05/01/18 06:05 PM
05/01/18 06:05 PM
Athens, GA
ctechbob Online content
ctechbob  Online Content
Athens, GA
If the engine rocks in the engine bay it wouldn't be the engine that's seized you wouldn't think. In order to rock the starter would have to be torquing against something in the driveline, if the engine is completely seized there should be no rocking.
Just a theory.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 311k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744842
05/01/18 06:26 PM
05/01/18 06:26 PM
Crown Point, IN
dan_erickson Offline
Crown Point, IN
Pretty normal for those 3v junks. Same thing happened to my old managers F-150
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744843
05/01/18 06:26 PM
05/01/18 06:26 PM
Chicago
Jooksing Offline
Jooksing  Offline
Chicago
Check the status of that oil. mine had no issues for a month and a half. turn out the "oil" was no good.
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744870
05/01/18 06:43 PM
05/01/18 06:43 PM
US
JLTD Offline
JLTD  Offline
US
Sorry to hear...it will be interesting to hear what the mechanic finds.
Speculate the main bearings. Or timing chain. Or both.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL‚ĄĘ
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: ctechbob] #4744896
05/01/18 06:54 PM
05/01/18 06:54 PM
RI
mattd Offline
mattd  Offline
RI
Just a theory.
This. I would look at the transmission before the engine. A seized engine will only make a ďclickĒ sound and no engine movement. With no warning or noise I find it hard to believe the engine is the issue.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: 2009 F150 5.4 3 Valve Engine Seized [Re: PReal] #4744936
05/01/18 07:24 PM
05/01/18 07:24 PM
PA
copcarguy Offline
copcarguy  Offline
PA
I'm guessing driveline not engine also.
Page 1 of 3 1 2 3
