NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
117 registered members (4WD, 69GTX, 69Torino, advocate, Ag76, 53' Stude, 15 invisible), 1,812 guests, and 33 spiders.
Topics296,897
Posts4,961,165
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 4 1 2 3 4
Magnetic oil drain plugs? #4743942
04/30/18 08:35 PM
04/30/18 08:35 PM
San Diego
trooplewis Offline OP
San Diego
Anybody use them?
Maybe I'm using the search function wrong, but I can't find any reference to them in the forums.
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743948
04/30/18 08:41 PM
04/30/18 08:41 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I bought one of those red/blue ones off Amazon
Gonna try it next oil change
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743950
04/30/18 08:43 PM
04/30/18 08:43 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Lots of industrial engines had magnetic drain plugs where I worked. the engines didn't last any longer than the engines with out magnetic drain plugs though. Reasonable interval oil changes are all that is needed for along engine life. Magnetic drain plugs can't hurt.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743955
04/30/18 08:46 PM
04/30/18 08:46 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No, no drain plugs
I put them here instead:
Originally Posted By: Linctex
Magnets are 8mm N50 neodymium
Re: Magnetic oil drain plugs? [Re: CT8] #4743959
04/30/18 08:48 PM
04/30/18 08:48 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Unless they do, of course.
AFAIK, nobody knows.
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743970
04/30/18 09:04 PM
04/30/18 09:04 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
A magnetic drain plug is only an indicator of wear, sort of an oil system snitch. Don't expect it to be something that it's not.
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743981
04/30/18 09:14 PM
04/30/18 09:14 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
I use it. Compared to the image above, it looks cleaner at 5-6k. It's my daily driver and rarely floor it.
I am sure that it will not collect all wear metals, maybe some iron, that's all.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743987
04/30/18 09:18 PM
04/30/18 09:18 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I have one on every fill and drain plug. Everything that doesn't have a plug gets it on the dipstick.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 104K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 37k Idemitsu 0w20, 57047
Re: Magnetic oil drain plugs? [Re: trooplewis] #4743996
04/30/18 09:29 PM
04/30/18 09:29 PM
Wethersfield Connecticut
Convert Offline
Convert  Offline
I use dimple drain plugs. You can check out the company on a search. Type in dimple drain plugs I believe their website is a dimple drain plugs.com. I use it on my on a 2013 Tacoma excellent and you can get rid of an allen wrench set up if your vehicle already has that these all are wrench sizes and it can use standard box wrenches
TOMB
TOMB
Re: Magnetic oil drain plugs? [Re: trooplewis] #4744003
04/30/18 09:35 PM
04/30/18 09:35 PM
WA
OilUzer Online content
OilUzer  Online Content
WA
Typically the oil filter should catch the metallic and non-metallic particles ...
They are used for differential or transfer case when there is no filter.
There is a possibility the drain plug may not match your OEM exactly (i.e. develop minors leaks) and the magnet can come loose. just saying there is a chance ... I have heard of oil leaks from friends but don't have a personal experience with magnet coming loose.
also have read the metallic parts that are now magnetized and attached together and to the magnet can separate from the magnet like a little ball and cause issues. This I am not sure since I have read it on the internet ... grin
edit:
also the drain plug with magnet maybe a little weaker since it is? hollowed out to insert the magnet ...
over time and with torque it may weaken and another potential for leak. engine oil is changed more frequently than diff oil ...
Re: Magnetic oil drain plugs? [Re: trooplewis] #4744014
04/30/18 09:46 PM
04/30/18 09:46 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
http://greddy.com/products/accessories/mag-drain/
One of the first things I did to mine along with going to Fram Ultra oil filter.
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
Re: Magnetic oil drain plugs? [Re: Ducked] #4744018
04/30/18 09:50 PM
04/30/18 09:50 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
They didn't hurt any of the engines that had magnetic drain plugs.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Magnetic oil drain plugs? [Re: trooplewis] #4744036
04/30/18 10:15 PM
04/30/18 10:15 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, use them in all my vehicles. They do catch ferrous material that the filter can't catch.
Re: Magnetic oil drain plugs? [Re: ZeeOSix] #4744043
04/30/18 10:44 PM
04/30/18 10:44 PM
WA
WA
if the ferrous material are big enough to see how can they go through filter?
just curious since I had debated about using them in the past but never did ...
I am open to change my mind smile
Re: Magnetic oil drain plugs? [Re: CT8] #4744054
04/30/18 11:44 PM
04/30/18 11:44 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Didn't say they did.
I said that as far as I know, no one knows.
And as far as I know, you don't either.
I have one. I also have a magnetic dipstick which I think makes a whole lot more sense.
That must be why they don't, AFAIK, exist, and I had to make it myself.
Page 1 of 4 1 2 3 4
