Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
95 registered members (4WD, 2015_PSD, 53' Stude, A310, 69Torino, 16 invisible), 1,850 guests, and 32 spiders.
Topics296,969
Posts4,962,601
Members67,009
Most Online2,821
Jan 21st, 2019
need help with a scan tool #4743457
04/30/18 01:01 PM
04/30/18 01:01 PM
PA
Chester11 Offline OP
PA
Hi folks:
I'm looking for a scantool that will pull fuel trim data. I'm running down a vacuum leak, and want to make sure it really IS a vacuum leak.
Here is what I'm looking at.
https://www.harborfreight.com/ZR8-OBD2-Code-Reader-with-Live-Data-63809.html
Thanks!
Re: need help with a scan tool [Re: Chester11] #4743464
04/30/18 01:08 PM
04/30/18 01:08 PM
California
VeryNoisyPoet Offline
California
That one claims live data and live data graphing. I don't have that exact model, but a similar one from HF with data and graphing. Very handy for looking at how the engine responds to various conditions.
It may also be possible that you are getting "pirate air", or air that slips in through a leak upstream of the throttle plate but downstream from the filter and MAF. This may not cause the same drivability issues as a vacuum leak, but will upset fuel trims and fuel economy.
What symptoms are you seeing? High idle? Rough running that improves with more throttle?
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: need help with a scan tool [Re: Chester11] #4743473
04/30/18 01:16 PM
04/30/18 01:16 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
You'd have to check their website's FAQ to see if it is offered for your vehicle, but if Live Data is offered for your application, the Bluedriver Scanner is an awesome tool to have. It's 10 dollars more, but offers bluetooth that allows you to pull up the information on your phone.
Re: need help with a scan tool [Re: VeryNoisyPoet] #4743503
04/30/18 01:36 PM
04/30/18 01:36 PM
PA
PA
It's a rough idle when in gear and hot. (Most noticeable at a stoplight). It improves with throttle.
In neutral or park, rpm increases a bit and the feeling goes away.
If you are interested, here is what I have done:
- replaced 2/3 motor mounts with no change. (The third mount looks ok)
- cleaned the throttle body
- replaced valve cover gasket
- also sprayed around lines / gaskets with water and carb cleaner but don't hear an idle change.
I'm thinking it could be a master cylinder / vacuum pump. (bad master cylinder would explain why the vibration is so bad at a light with the brake on - my theory anyway, as braking has seemed to deteriorate in the last few years). But before I go replacing parts, I want to see the fuel trims.
Thanks.
Re: need help with a scan tool [Re: Chester11] #4743519
04/30/18 01:49 PM
04/30/18 01:49 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
How about a Bluetooth one for phone and Torque?
2015 Ford F250 w/Powerstroke
Re: need help with a scan tool [Re: Chester11] #4743538
04/30/18 02:03 PM
04/30/18 02:03 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
What Donald said.
I have an old Samsung Galaxy S3 phone that I wiped and installed Torque Pro on. Torque Pro costs $4.99, and will read most Bluetooth OBD-II adapters fine.
I bought an inexpensive adapter on Amazon for about $13. This Adapter - VeePeak Bluetooth OBD-II adapter
I also got a magnetic-mount vent-clip phone holder for about $8. Holds the phone amazingly well.
The setup as a whole works great. Here's a shot of it mounted:
I typically leave it on this screen to get a second set of info while I drive, but I have other screens setup to show Long Term and Short Term Fuel Trim, O2 sensors (pre and post), Spark advance timing, Vacuum sensor, EGR %, etc..
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: need help with a scan tool [Re: SirTanon] #4743742
04/30/18 06:05 PM
04/30/18 06:05 PM
PA
PA
wow - cool. only problem is that I don't have Android. I will have to look at the apple versions....
thanks - that is much cheaper than my pick.
Re: need help with a scan tool [Re: Chester11] #4744197
05/01/18 06:11 AM
05/01/18 06:11 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
That's a nice unit for the money. Made by Innova who makes some good products.
Re: need help with a scan tool [Re: Chester11] #4744373
05/01/18 10:10 AM
05/01/18 10:10 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I would be using a MityVac to check for vacuum leaks.
Re: need help with a scan tool [Re: zzyzzx] #4744386
05/01/18 10:21 AM
05/01/18 10:21 AM
PA
PA
at the brake booster you mean?
Re: need help with a scan tool [Re: Chester11] #4744887
05/01/18 06:51 PM
05/01/18 06:51 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Thanks.
I'm all for you buying a scan tool & learning how to use it! But.....A good diagnostic tech can figure out your issue very quickly. Case in point about the master cylinder causing driveability concerns....Probably not your issue unless your losing brake fluid? You can usually HEAR a ruptured brake booster diaphragm.
Make/Model of the vehicle?
2001 Chevy Camaro L92/4L80E
Re: need help with a scan tool [Re: clinebarger] #4745102
05/01/18 10:42 PM
05/01/18 10:42 PM
PA
PA
2007 Mazda 6i (2.3).
Yep - understand, it's an older car that I kinda like messing with. No leaks, but I did find out that the in line check valve seems slightly restricted (it sounds a bit like a trumpet and not an easy flow). It appears that I have to replace the entire hose, which is $94! Mazda parts are somewhat challenging to find, but that is crazy. I also posted on a Mazda specific forum to see if they had ideas. I would hate to make a junkyard run for a hose.
Re: need help with a scan tool [Re: Chester11] #4745835
05/02/18 05:20 PM
05/02/18 05:20 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The check valve just needs to flow one way & check the other way, The vacuum signal the engine makes is very strong so what seems like a restriction to you isn't.....Engine vacuum will easily overcome the check valve spring pressure.
Re: need help with a scan tool [Re: clinebarger] #4745873
05/02/18 05:49 PM
05/02/18 05:49 PM
PA
PA
that's what I was thinking - but thanks for confirming. I'm running out of places to look - so it might be time to just deal with it. what has me stumped is the RPM drop that occurs when you press and hold the brake for about 5 / 7 seconds. it feels almost like a downshift, but happens at a dead stop also.
Re: need help with a scan tool [Re: Chester11] #4745930
05/02/18 06:38 PM
05/02/18 06:38 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Remove the booster hose from the intake manifold, plug the port & retest....Be careful as you will NOT have brake assist!!
If your running at speed....Applying the brakes will unlock the torque converter.
Trying idling at a stop light with the parking brake instead of the service brakes & see if it improves.
A scan tool would help you see if the actual idle speed is lower than the target idle speed. I would also take a closer look at the old mount that looks good!
Take a floor jack with a thick piece of rubber & take the weight off that mount & see if the vibrations go away.
Mounts can visually appear OK but be collapsed internally, Does the engine torque on this mount in drive??
