Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
109 registered members (ammolab, advocate, 69Torino, 1.8Tango, 4WD, andyd, 11 invisible), 1,796 guests, and 33 spiders.
Topics296,898
Posts4,961,183
Members66,997
Most Online2,688
Yesterday at 11:12 AM
Page 1 of 3 1 2 3
Shearing = shift quality degradation... ? #4743431
04/30/18 12:29 PM
04/30/18 12:29 PM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
I have read almost every thread discuss how shift quality deteriorates over the course of an OCI. Is this directly caused by the level of shearing an oil experiences? Or is there something else at play?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743485
04/30/18 01:24 PM
04/30/18 01:24 PM
Arkansastan
Propflux01 Offline
Propflux01  Offline
Arkansastan
Yes, a lot of it is. Gears shear the [censored] out of oil, and most motorcycles share the sump.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743515
04/30/18 01:48 PM
04/30/18 01:48 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
This has been the case for many years with shared sump bikes/quads. I've dealt with it for a long time in just about every make and model. My current '11 KingQuad 400 shears oil fast and gets very notchy within 500miles. My 08 Kawasaki Ninja 650 does also when using the recommended 10W40 lube. I even went with some Castrol 10W40 full syn this time and it lasted longer but still gets very notchy after 1000 miles or so.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743553
04/30/18 02:23 PM
04/30/18 02:23 PM
webfors Offline OP
webfors  Offline OP
In which case your viscosity choice should compensate for 20-30% shearing in a shared sump if you want to maintain decent shift quality for the majority of the OCI.
Or... use an oil that doesn't shear... which is rare.
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743654
04/30/18 04:20 PM
04/30/18 04:20 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yes as oil ages in a shared sump motorcycles the polymer VII are sheared or cut by the mechanical action of the gears. This causes the viscosity to drop and the gear change to go bad. Notchy at first, but soon you end up missing gear changes or requiring a lot of boot to get it into gear.
I tend to run thicker oils so they shear into grade after 1000 miles, rather than out of grade.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743659
04/30/18 04:26 PM
04/30/18 04:26 PM
Portland, Oregon
Joshua_Skinner Offline
Portland, Oregon
My 1998 Honda VFR 800 shifts fine throughout the 5k mi OCI. I've been using Mobil 1 5W-40 Turbo Diesel Truck that I got on clearance at Auto Zone. Once that's gone I'll use the Pennzoil Platinum Euro 0W-40 I got on clearance at WalMart.
2015 Nissan Frontier S King Cab, 2.5L, 5MT
Pennzoil Platinum 5W-30 in the crankcase. Red Line in the gearboxes.
Re: Shearing = shift quality degradation... ? [Re: SR5] #4743671
04/30/18 04:37 PM
04/30/18 04:37 PM
webfors Offline OP
webfors  Offline OP
This is what I'm thinking with the recent purchase of Valvoline 20w50.
Re: Shearing = shift quality degradation... ? [Re: Joshua_Skinner] #4743672
04/30/18 04:38 PM
04/30/18 04:38 PM
webfors Offline OP
webfors  Offline OP
Your bike doesn't require Jaso spec oil?
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743744
04/30/18 06:06 PM
04/30/18 06:06 PM
pa
benjy Offline
benjy  Offline
pa
any type of oil using a smaller spread will use less VII that shear, an oils first # besides the cold flow is what base oil is used before adding VII so a 15-40 is inherently better than 10-40's + the quality of the VI's are many. cheap oil cheap polymers aka VII. of course you must consider riding temps as well!!! true synthesised synthetics are far better requiring very little VII + generally last longer if you don't mind paying $10+ a quart, of course there are other benefits as well. those that DIY can easily change their oil sooner + be better protected + have better shifting. rotella T 15-40 a cheaper conventional diesel oil is quite popular for that reason !!!
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743792
04/30/18 06:45 PM
04/30/18 06:45 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Most bikes run fine with diesel oil. No "Energy Conserving" on diesel oil so no clutch issues.
I run Peak 15w-40 syn blend diesel oil in my bike, and have used Supertech 15w-40 as well.
I am just starting to notice some notchiness in shifting and difficulty finding neutral @ 2200 miles on the oil, so will be changing it soon.
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743817
04/30/18 07:01 PM
04/30/18 07:01 PM
Greece
Panos Offline
Panos  Offline
Greece
No shifting degradation ever experienced in both of my bikes (see my signature) using motul oil only.uoa showed pretty decent sharing also in both of them. Never felt any difference during the interval or after changing the oil (which I did about 15 times in 85.000km total)
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Shell Advance Ultra 4T 10w40
Honda cbr600f Pc41 Motul 7100 10w30
Re: Shearing = shift quality degradation... ? [Re: Panos] #4743847
04/30/18 07:19 PM
04/30/18 07:19 PM
webfors Offline OP
webfors  Offline OP
So that's interesting.. because your UOA showed significant shearing, yet you noticed no difference in shifting quality..
Re: Shearing = shift quality degradation... ? [Re: webfors] #4743928
04/30/18 08:13 PM
04/30/18 08:13 PM
blupupher Offline
blupupher  Offline
Some bikes are not as susceptible to shifting problems from shearing as other bikes.
Re: Shearing = shift quality degradation... ? [Re: webfors] #4744063
05/01/18 12:07 AM
05/01/18 12:07 AM
Greece
Panos Offline
Panos  Offline
Greece
That's also my conclusion after reading and hearing so many reporting shifting quality difference. At the same time , very few people I know or post here seem to use the motul brand.
Re: Shearing = shift quality degradation... ? [Re: Panos] #4744082
05/01/18 01:09 AM
05/01/18 01:09 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
I've tried most brands out there over the years, and Motul 300V 4T is my favorite. The bikes run great, and shift perfectly for the entire OCI. I've tried numerous HDEO's, and the shifting always quickly degrades in my bikes.
Page 1 of 3 1 2 3
