yes, use champ plugs, not some iridium or platinum, clean the TB, if doing the 41TE, use a Mopar filter, REdline C+ is an excellent fluid, also the PSfluid should be serviced same ATF, coolant is Zerex G5
these cars LCA suck, use Moog problem solvers if you have to do the bushings.
The 2.4 run great.
