Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
103 registered members (advocate, AndyB, 69GTX, ammolab, 69Torino, 1.8Tango, 9 invisible), 1,721 guests, and 33 spiders.
Topics296,898
Posts4,961,190
Members66,997
Most Online2,688
Jan 19th, 2019
Video: How much horsepower does your oil pan rob? #4742313
04/29/18 11:07 AM
04/29/18 11:07 AM
Pacific NW USA
GemStater Offline OP
Pacific NW USA
I already used up my Motor Trend on demand trial so I haven't seen the final results but this looks interesting...
06 Honda Accord EX-L 3.0L - Mobil 0W-20 AFE | Fram XG7313
02 Dodge Grand Caravan 3.3L - PP 5W-30 | Fram Ultra XG8A
69 Plymouth Road Runner 383 - Project car
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742325
04/29/18 11:14 AM
04/29/18 11:14 AM
ME
eljefino Offline
eljefino  Offline
ME
It's a "known fact" among prius drivers that running 1/2 quart low (from the top pip of the stick) has MPG gains.
Re: Video: How much horsepower does your oil pan rob? [Re: eljefino] #4742327
04/29/18 11:17 AM
04/29/18 11:17 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
And draining half of your blood supply can make you lose weight.
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742339
04/29/18 11:30 AM
04/29/18 11:30 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
About the same amount as blowing your nose!
2004 Corolla 128276
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Video: How much horsepower does your oil pan rob? [Re: eljefino] #4742365
04/29/18 11:53 AM
04/29/18 11:53 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This has been common knowledge in engines for years.
Many racers in "stock" (very strict rules) classes will only run 3 quarts in a 5-qt V8 engine oil pan.
In a 12 second drag race, you only need oil pressure for the 12 seconds of run time. If 2 quarts would do the trick, they would do it.
"Crankcase windage" can kill 10HP easily - at rated RPM.
Normal "grocery getter commuter cars" typically will never see a difference in anything if run a whole quart low.
Yes, I am serious!
Did you ever think the new Nissans with only a 3 quart capacity might have other reasons for their decision ?!?!!? Everyone is trying to get better MPG across the fleet.
EDIT: OK, I just watched the video. That was no surprise at all.
If they keep pulling oil out, HP has to go higher. It ALWAYS does!
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742425
04/29/18 01:14 PM
04/29/18 01:14 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
The difference does not show up until 4,000 rpm, so donít bother unless you like operating there.
If you want the job done right......do it yourself.
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742433
04/29/18 01:23 PM
04/29/18 01:23 PM
USA
E365 Offline
E365  Offline
USA
I wanted them to put 0w-16 in there and see if power was gained! laugh
Whateverís on sale...
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742518
04/29/18 02:53 PM
04/29/18 02:53 PM
Charles City, Iowa
rideahorse Offline
rideahorse  Offline
Charles City, Iowa
Every thing runs the best right before it blows up.
Re: Video: How much horsepower does your oil pan rob? [Re: eljefino] #4742667
04/29/18 05:35 PM
04/29/18 05:35 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
I don't know about that "fact," but I'm careful not to refill mine with more than the specified volume---which incidentally does not bring the level all the way to "the top pip of the stick," only about 90% of the way up from the lower pip.
2011 Toyota Prius now at 95K
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742678
04/29/18 05:41 PM
04/29/18 05:41 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
How much horsepower does your oil pan rob? - Er, none. Trick question? Or maybe stupid question?
How much horsepower does your oil amount rob? - Er, none. unless the oil level is excessive?
How much horsepower does an excessive oil level rob? - Er, quite a lot, because the crankshaft hits it.
This is not news.
The assumption in the above discussion that Less=More seems unlikely to be generally valid. I;d expect there to be a cutoff below which you wouldn't gain much if any horsepower but might loose your engine
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742689
04/29/18 05:53 PM
04/29/18 05:53 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
The after market oil pan must be poor quality. Too much drama for a mans program.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4742742
04/29/18 06:51 PM
04/29/18 06:51 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
With a well designed windage tray, there should be little or no difference in high to low on the dip stick.
If you really want to save HP at RPM, you go dry sump and vacuum pump. You pay something for the pumping losses, but not as much smile
Re: Video: How much horsepower does your oil pan rob? [Re: Linctex] #4743044
04/30/18 06:44 AM
04/30/18 06:44 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Yes, I am serious!
I don't understand. The oil is still pumping regardless of the volume in the sump. I can see the 3 quarts warming up faster, but I would assume the engines would already be hot.
Also, some cars fitted for drag racing (obviously not stock) have over sized sumps.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4743088
04/30/18 07:32 AM
04/30/18 07:32 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Thinking about it a bit more, I think I not sure exactly what was going on here either.
I'd always assumed that the issue with over-filling was the crank actually hitting the oil surface, but I guess the term "windage" implies its actually rotating air entrained by the cranks motion and blowing oil off the surface.
If that's the case the horsepower loss may be partly due to air resistance, and maybe there won't be a sharp cutoff like there would be if hitting an oil surface.
I'd also assumed the dry-sump thing was to avoid oil starvation due to the oil going sideways due to lateral G's, and pumping losses from the piston underside pushing air around. Hadn't thought of air resistance to the cranks riotation.
Re: Video: How much horsepower does your oil pan rob? [Re: GemStater] #4743131
04/30/18 08:01 AM
04/30/18 08:01 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Another thing is there were V-8 engines, (Oldsmobile and Buick among them), that had issues with the oil pump starving out because the oil couldn't drain back into the oil pan fast enough. Forcing the oil pump to basically to suck wind instead of oil. This led to bearing failure as oil pressure would fall to zero if the engine were run for any length of time at high RPM's. (Above 4,500 RPM). Like in jet boat applications. There were even kits that could be installed in these engines that would somehow prevent this from happening.
When I lived in Lake Havasu City, my neighbor had a race boat with a 455 Oldsmobile "Rocket" V-8 in it. He told me about this, and showed me the kit he installed in the engine to prevent it. He warned me if I was ever in the market for this type of boat, (Oldsmobile / Buick V-8 powered), and it did not have this kit installed, to run, not walk away from it. Running an engine of this type low on oil would make an already bad condition even worse. Deliberately running any engine with less than the rated oil capacity just seems foolish.
http://www.hotrod.com/articles/0302phr-oldsmobile-455ci-engine-build/
"The narrow passages from the stock heads do not allow oil in the valvetrain to return to the pan in an efficient manner. This condition can lead to instant death for a 455 that is run wide open for extended periods of time."
