Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
82 registered members (AdRock, askani79705, 69GTX, asiancivicmaniac, aleneros, 9 invisible), 1,171 guests, and 42 spiders.
Topics297,006
Posts4,963,324
Members67,013
Most Online2,821
Jan 21st, 2019
Page 1 of 3 1 2 3
Jeep pinging more. #4741625
04/28/18 04:57 PM
04/28/18 04:57 PM
Northeastern Vermont
littleant Offline OP
My 2002 jeep 4.0 158,000+ miles is pinging more then it use to. Would go as far as saying excessive. I think the issue maybe in the last year wife now works in town 1 mile round trip. I do take it for run once a week on a 50 mile trip but speed is not over 50. I think I am getting carbon buildup. Tried gumout regane no help. Years ago in my repair shop i would do slow slow water drip down the carburetor (remember them) and it would work. The jeep has port injection i believe. Any issues dripping down the Throttle Body. Any better ideas?? Thank you
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Jeep pinging more. [Re: littleant] #4741626
04/28/18 04:59 PM
04/28/18 04:59 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Use a higher octane gas.
Re: Jeep pinging more. [Re: littleant] #4741628
04/28/18 05:02 PM
04/28/18 05:02 PM
Tried that first. Very minimal change.
Re: Jeep pinging more. [Re: littleant] #4741633
04/28/18 05:17 PM
04/28/18 05:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Some weekend, pull the plugs and put 2oz (~70ml) of sea foam in each hole.
Start the plugs threaded in, but not tight. Don't connect the ignition coils.
Crank the engine for 5 seconds to splash it around in there, then let sit for 24 hours.
Tighten the plugs, connect the coils, then take it out for a little highway cruise.
From this point forward, add 2-cycle oil to the gas at 1oz per every 5 gallons (1:640)
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1107478/
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1429603/
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2486832/
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3015734/
Re: Jeep pinging more. [Re: littleant] #4741636
04/28/18 05:19 PM
04/28/18 05:19 PM
US
JLTD Offline
JLTD  Offline
US
There could also be water in the tank - I had an older vehicle that pinged until I put some HEET or similar to clean it out.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Jeep pinging more. [Re: Linctex] #4741638
04/28/18 05:26 PM
04/28/18 05:26 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
I've heard of this too...
Isn't it with tcw3 2 cycle oil?
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Jeep pinging more. [Re: littleant] #4741642
04/28/18 05:30 PM
04/28/18 05:30 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Just a thought if your burning oil could be valve stem seals.
valve stem seals
Pete.
Re: Jeep pinging more. [Re: rollinpete] #4741644
04/28/18 05:37 PM
04/28/18 05:37 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Isn't it with TCW-3 2 cycle oil?
Yes sir...
Original thread started here, actually:
http://www.ls1.com/forums/f48/been-testing-oil-91206/
Re: Jeep pinging more. [Re: Linctex] #4741656
04/28/18 05:52 PM
04/28/18 05:52 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
Yes sir...
It's for some interesting reading, I've read most of it before, I just can't make myself to believe putting more oil in your combustion chamber would make it run cleaner.
Pete.
Re: Jeep pinging more. [Re: littleant] #4741662
04/28/18 05:55 PM
04/28/18 05:55 PM
Linctex I will try the sea foam. Interesting about 2-cycle oil to the gas at 1oz per every 5 gallons. Thank you for the links. I Appreciate that.
Re: Jeep pinging more. [Re: rollinpete] #4741664
04/28/18 05:58 PM
04/28/18 05:58 PM
valve stem seals
Believe it or not even at the mileage the engine burns no oil. Never had a vehicle that did not use some oil between oci.
Re: Jeep pinging more. [Re: rollinpete] #4741677
04/28/18 06:10 PM
04/28/18 06:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
TCW-III is ashless, so leaves no deposits.
It has some type of "carbon remover" in it to help keep exhaust ports clean on 2-cycle engines.
1:640 is a pretty lean ratio
Re: Jeep pinging more. [Re: littleant] #4741685
04/28/18 06:16 PM
04/28/18 06:16 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Inline Six is pretty easy to do piston soak. I like Break Free gun solvent overnight. It's made to help clean carbon from rifle bores. Once it has softened the carbon, it should burn off on a good highway run laugh
Can you take 1* or 2* of timing out of it? They may have switched to summer gas formula and the engine is reacting ...
Re: Jeep pinging more. [Re: littleant] #4741686
04/28/18 06:17 PM
04/28/18 06:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Hmmmmm........ interesting video
Re: Jeep pinging more. [Re: Linctex] #4741689
04/28/18 06:18 PM
04/28/18 06:18 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Great. After some reading I may get back on the tcw 3 wagon.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Page 1 of 3 1 2 3
