Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
98 registered members (4WD, 69Torino, 1.8Tango, 97prizm, 53' Stude, 11 invisible), 1,788 guests, and 42 spiders.
Topics296,895
Posts4,961,137
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
Can't Shift to into First gear while moving #4741347
04/28/18 09:35 AM
04/28/18 09:35 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Hi.
i have always belived that in my car, it is not possible to shift first gear if you are moving. It is impossible to shift even at 5- 10Km/Hour speed. Since i am generally in traffic jams, i have to shift to first gear very frequently.
But today i tested 2 different cars of the same model, and i was able to shift to first gear even when i was driving at 50Km/hour.
In my car, it is even difficult (but possible) to shift to second gear when going at 40Km/H speed.
In this case, the first thing that comes to a mind is the synchronizers. But they are not sold as a spare part in my country. so instead, it would be cheaper to buy an used transmission. (transmission and labor work would cost about 150$ which is ok for me)
But some mechanics told that it can also be due to bad pressure plate.
Can you please tell me if any thing else cause hard shifting on move other than synchronisers ?
We tried to adjust pedal-transmission connection. both from under the padal and by lengthening slave cylinder rod,
But none helped.
Regards
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741350
04/28/18 09:40 AM
04/28/18 09:40 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
What is the max speed you should be in for 1st gear? Are you asking if you can shift from 4th gear to 1st gear while moving?
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741352
04/28/18 09:42 AM
04/28/18 09:42 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Your not supposed to be able to access first gear when moving.
It's a safety feature that has been implemented into the design. Older cars generally don't have this feature
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741354
04/28/18 09:47 AM
04/28/18 09:47 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Try it without the clutch. As your slowing down put it in neutral. When the engine and road speed match it will slip right in.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741364
04/28/18 10:15 AM
04/28/18 10:15 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
I do not want to shift from 4 to 1 or 3 to 1, But i need to shift from 2 to 1 when i am driving at 15-20km/h.
Why need this is because i am driving generally at traffic jams and hills. My cars engine is only 1.5l So sometime i have to drive it at high rpm at lower speeds. Especially when the car is full.
I tried other cars with the same transmissions. i was able to shift to 1 while the speed is 50km/h. (I didn't released the clutch pedal after shifting to 1 in order not to cause any damage to engine and/or to the transmission.)
So it means there is a problem with my transmission. Just trying to find out what it is smile
REgards
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741378
04/28/18 10:30 AM
04/28/18 10:30 AM
ME
eljefino Offline
eljefino  Offline
ME
Sounds like your driving style needs improving. Learn to double-clutch, that is, lift the clutch in neutral, blip the throttle, then hit the clutch and go for the lower gear simultaneously.
If you put in a used transmission you'll wear it out, too, driving like you do.
However, a trans with worn-out synchros provides excellent feedback to the driver learning how to double-clutch. Find some videos on youtube and train yourself. Once you get good, you won't wear your replacement transmission.
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741381
04/28/18 10:32 AM
04/28/18 10:32 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Is there any pedal free play? Is the clutch linkage adjustable? If hydraulic, bleed the slave cylinder. Is the lube level in the transmission full? These are things I would check before I touched a wrench
Thick oil is better grin2
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741385
04/28/18 10:34 AM
04/28/18 10:34 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
1st & reverse are often without sychros...thats normal...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741389
04/28/18 10:35 AM
04/28/18 10:35 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Do you know the year, make and model of the car you're talking about?
I had a 94 Honda Civic that did the same thing when trying to go into first. Bought the car new and did it from day one. Getting into reverse could be a chore at times also.
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741403
04/28/18 10:54 AM
04/28/18 10:54 AM
Frogland / Brittany / Canada
Popsy Offline
Popsy  Offline
Start by changing gear oil... couldn’t do that in my [censored] when I bought it at almost 200K, changed the probably original oil, and all suddently it’s way easier/possible to pass the first gear from low speed, like just before stopping.
But first, what car, and when was the transmission oil changed last. Also,what kind of clutch control, cable or hydraulic actuated?
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 0W40 | Colt Ralliart, 300V 0W40
Re: Can't Shift to into First gear while moving [Re: SatinSilver] #4741434
04/28/18 11:34 AM
04/28/18 11:34 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
As they said, some transmissions do this « by design ». I only had MT cars, so I can tell that at least 1 out of 2 was impossible to downshift from 2 to 1st gear while moving
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealer’s overfilled, 16000 Km
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741439
04/28/18 11:37 AM
04/28/18 11:37 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
My old Focus ZX5 went into 1st gear while moving no problem, I rev matched for a smoother transition, but I didn't have to double clutch. That means the first gear was synchronized. As far as I;m aware, I never heard of any safety feature that would prevent shifting into first. That would be a liability not a feature.
From the sounds of it, the first gear in this car may not be synchronized, which was common on older cars. I would try double clutching and rev matching technique. It should work, if it doesn't then there is something wrong with the transmission.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: Can't Shift to into First gear while moving [Re: eljefino] #4741441
04/28/18 11:40 AM
04/28/18 11:40 AM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
thumbsup Would rather learn this than swap a transmission.
There's no replacement...'scosity for natural viscosity
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741475
04/28/18 12:50 PM
04/28/18 12:50 PM
NY, USA, etc.
oilpsi2high Online content
oilpsi2high  Online Content
NY, USA, etc.
Could be low transmission fluid, or the clutch not working like it should.
Try shifting into another gear before going into first.
Re: Can't Shift to into First gear while moving [Re: NICAT] #4741478
04/28/18 01:01 PM
04/28/18 01:01 PM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Thanks for replies and good advices.
Well, as stated above, i have already tested same model cars with the same transmissions. And they are quute easy to shift.
So the design is not the culprit.
Several other people drived the car, and they also noted that how uncomfortable the gear shifting is.
My car anyway has 1M km on it. The transmission should be worn a lot. And replacement transmission +labour work cost as 150$, which is quite reasonable price.
I will try to learn double clutching, let me see if it helps. smile
Regards
Page 1 of 3 1 2 3
