Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
105 registered members (97prizm, 1.8Tango, 2015_PSD, 2003f7, 14 invisible), 1,661 guests, and 33 spiders.
Topics296,611
Posts4,955,827
Members66,950
Most Online2,577
Jan 14th, 2019
mobil 1 delvac 5w-40 ESP UOA #4740199
04/27/18 05:39 AM
04/27/18 05:39 AM
Queensland Australia
mitchellp Offline OP
This is my used oil analysis from my 2010 Jeep Wrangler JKU CRD turbodiesel travelled approximately 12,000 km Or 7456 miles on the oil let me know what you guys think
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4740255
04/27/18 06:46 AM
04/27/18 06:46 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Typical Mobil products showing high iron! I'd bet money if you switch to Rotella T6 that would drop significantly...
Marginal amount of Zinc and low Moly, nothing that makes me want to run this oil in my diesel.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: mobil 1 delvac 5w-40 ESP UOA [Re: racin4ds] #4740296
04/27/18 07:34 AM
04/27/18 07:34 AM
Michigan
Buzzinhalfdozen Offline
Michigan
Considering this is CJ4 (from diagnosis section on report) it has more zinc than the Rotella t6 CK4 suggested above.
1332 PPM is hardly marginal in a HDEO it's quite comparable to any other CJ4.
Rotella also has no moly so not sure if racin4ds is a Mobil hater or just Rotella fanboy.
To me this report looks fine. Oil stayed in grade. TBN is low, but you changed it. Statistically it's impossible to draw any conclusions from one data set.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2L
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4740822
04/27/18 05:18 PM
04/27/18 05:18 PM
Yeah the TBN is very low which I thought was strange as my EGR is blocked I would’ve thought it would’ve been higher is it possible the test results are incorrect
Re: mobil 1 delvac 5w-40 ESP UOA [Re: Buzzinhalfdozen] #4743047
04/30/18 06:50 AM
04/30/18 06:50 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Mobil 1 Hater AND Rotella Fanboy thank you!
Regardless of Rotella's new formulation, I'd bet his Fe numbers go down with any other oil used... large scale complaints of noise and high Fe is why I will NEVER use a Mobil 1 oil again. I've personally witnessed it in many of my own vehicles, and I used to LOVE their oils...
Not to mention the cost of this supposed "superior oil" and its junk after 7400 miles with that TBN? No thanks...
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: mobil 1 delvac 5w-40 ESP UOA [Re: racin4ds] #4743089
04/30/18 07:34 AM
04/30/18 07:34 AM
Texas
4WD Offline
4WD  Offline
Texas
Did you read the Blackstone summary report and see where Delvac 1 landed … if you did you ignored the great results …
Anyone surprised?
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4743354
04/30/18 10:49 AM
04/30/18 10:49 AM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
It seems to be a trend with CK-4 the molybdenum is going away. It makes me want to switch to AMSoil, atleast they sell actual CJ4 oil with molybdenum.
Re: mobil 1 delvac 5w-40 ESP UOA [Re: Fraser434] #4744085
05/01/18 01:14 AM
05/01/18 01:14 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I don't believe the product had moly in CJ-4, either.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: mobil 1 delvac 5w-40 ESP UOA [Re: Fraser434] #4744191
05/01/18 06:07 AM
05/01/18 06:07 AM
Idaho
BoiseRob Offline
BoiseRob  Offline
Idaho
Schaeffer 9000 5w40 is still CJ4 with Moly...
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4760495
05/17/18 10:42 PM
05/17/18 10:42 PM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
Considering that's 11k mile run 23ppm iron is pretty good. I think racin4ds isn't taking that into consideration id be surprised if delo or t6 would show much better results.
Give delo or T5/T6 a shot on 11k mile run now im curious lol.
16 Silverado 2500 6.6 LML Dmax
15w-40 Mobil Delvac
Fram Ultra XG9100
Filter Mags: Fuel filter, Allison and engine.
CAT Coolant Filter, Wix Air Filter, K&N Cabin Filter
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4768357
05/25/18 09:36 PM
05/25/18 09:36 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
For only 7400 miles (12,000KM) I'm not entirely impressed with the TBN. As for the wear numbers...more samples over time will tell if it's normal or not.
HDEO in Diesel Engines. No spark plugs here.
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4775212
06/02/18 07:39 AM
06/02/18 07:39 AM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
Note that the TBN was measured with IR spectroscopy. I wonder what it would be done by the old acid titration method. I agree that it is very disappointing especially with EGR delete. On my Unimog it came back 11.4 after 25k mi using higher sulfur fuel about half the time. Starting TBN about 15-16, 8L makeup in a 30L sump.
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: mobil 1 delvac 5w-40 ESP UOA [Re: Shata] #4776929
06/04/18 06:39 AM
06/04/18 06:39 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Actually Shata, it was a 11,000 km run, which is 6600 miles. Also, Piper One, the vehicle had 120,000 km and the run was 11,000 km.
Happy to help out. smile
If you want the job done right......do it yourself.
Re: mobil 1 delvac 5w-40 ESP UOA [Re: mitchellp] #4776934
06/04/18 06:49 AM
06/04/18 06:49 AM
Snagglefoot Offline
Snagglefoot  Offline
Not sure how the system on a diesel works. Where are the blow-by gases going? Where they supposed to enter the EGR or do the have a PCV system like a gasoline engine.
