This truck is for a friend of mine with a grass cutting business, 2011 Chevy 1500 4x4 with 233k miles. It pulls 5000 pounds six days a week. Being its how he makes his living, he tries to take care of it as best as he can. He bought it with 220k, it had a leaking rear main seal, dealer changed it and said the oil pan gasket would need to be changed also. It doesnt leak but you can wipe the oil off around the tranny/oil pan and two days later itll have oil again, but it doesnt leak or drip onto the ground, level doesnt drop much either. Hes been using Maxlife Syn 10W30 and a TG filter, chnaging every 5k. We plan on dropping the front diff and changing the oil pan gasket as soon as he gets time, I have access to a lift. Would it be ok to just run some cheap Supertech 15W40 and change it when the OLM hits 0%? Or stick with the current regimen?
