Hello all
I've been having a low speed wobble in the wheel when returning to center, as well as when taking long sweeping turns at low speed. So far I've replaced the tires with new Michelin Primer A/S tires and had the alignment done, as well as balanced (and re-balanced) the tires, but to no avail. The front end parts on my car are original, but I pulled the wheels and looked at the compliance bushings and they look new, and everything felt tight and "looked" new. The car is a 95% freeway cruiser and has lived a pretty easy life. Do you all suspect this could be my steering rack?
The only caveat I'd throw in is a new driver's side axle (aftermarket) about 40k miles ago due to a torn boot. It seems to have been fine, but this wobble has me wondering if that may be the culprit.
