Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
B&S riding mower long filter short filter etc.
by j_mac - 11/11/19 05:32 PM
Covering the cowl vent
by painfx - 11/11/19 05:31 PM
Project: DuckHead Arm
by RayCJ - 11/11/19 05:29 PM
I Found The Perfect Garage Door Oil
by billt460 - 11/11/19 02:03 PM
Oil recommended for Old Snowthrower
by Ckerch - 11/11/19 01:58 PM
Choo Choo train maintenance and repairs?
by Chris142 - 11/11/19 01:58 PM
Hemi Oil Use
by Zap1967 - 11/11/19 01:27 PM
Who Makes the Best Class 8 "Semi" Truck These Days?
by LoneRanger - 11/11/19 01:21 PM
Update to my Wide Open West Broadband Thread
by LoneRanger - 11/11/19 01:15 PM
Is it worth changing my Corolla oil before 10k?
by oxband - 11/11/19 01:10 PM
Blowing smoke in 1970 Chevelle
by 007 - 11/11/19 12:05 PM
Coolant leak parked in the cold
by OCDriver - 11/11/19 11:58 AM
Where can I get a dumb battery charger?
by Chris142 - 11/11/19 11:56 AM
THANK YOU to ALL the Veterans that served.
by BAJA_05 - 11/11/19 11:22 AM
oxband, coachmorin, michaelpbreen, Zap1967, corleco
69826 Registered Users
118 registered members (Astro_Guy, 25ring, AtlasFBG2, 2015_PSD, 2_Tall_Mitchell, 69Torino, 9 invisible), 2,201 guests, and 22 spiders.
Topics297,281
Posts5,112,210
Members69,826
Most Online3,589
Nov 2nd, 2019
03' 2.3 Ford Focus / Dash light on steadly #4735643 04/22/18 07:47 PM
O
Oregoonian Offline OP
O
Just recently, the engine dash light turned on, and is on steadily . Per manual....it indicates some issue with emissions.
Before I take it to a mechanic, is there some way (without cost) to determine what the issue could be. Vehicle has 146 K on the OD.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4735647 04/22/18 07:50 PM
spasm3 Online Happy
Online Happy
If there is an autozone parts store near you, they check cel codes for no cost. Its a starting place. Just reseach the codes. Do not let them start selling you parts, until you do your homework.
Some parts are ok aftermarket. Some things like egr solenoids, tps etc are better from OEM.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles m1 0w40
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4739813 04/26/18 04:22 PM
O
O
A relative told me he recently had the same issue (Engine Dash Light) on. He decided before doing any expensive work on the emissions system....he would just changes out the fuel filter.
Since that is a fairly cheap thing to do....I did it. (I had previously changed the fuel filter out about 50K ago). Low and behold it worked...and cost me very little to do. NO MORE ENGINE DASH LITE ON). Vehicle runs nice and smooth again.
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4741132 04/28/18 12:46 AM
T
tbm3fan Offline
T
You're next issue that should come up soon will be a crack in the pcv hose behind the intake manifold. I've already had to change mine out. Several hours to do so best to change valve also.
2018 Mazda 3
2004 Buick LeSabre
2004 Focus
1998 Sable
1991 Mazda 626
1973 Polara
1968 Cougar
1968 Mustang
1967 Park Lane
1965 F-100
My toy: USS Hornet CV-12
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4741141 04/28/18 01:23 AM
O
Olas Offline
O
If you have a cheap reader, plug it in.
If you have a can of deodorant of other flammable aerosol, spray it around the engine and listen for changing rpm.
Cable ties should hold it
