I have a no start Ryobi CS30 string trimmer. It worked great for years then I had problems starting and if it did it would eventually stop running for no obvious reason. I replaced the carb and even the ignition coil as well as a new spark plug. Once in a while I could get it started to run for a few minutes, but not usually. Also the fuel tank and lines are new. The other day I got it to start after dozens of pulls. It ran great for a brief period but it stopped and I could not get it started again. This engine is not rocket science but I have to admit I'm stumped. It's been a personal jihad to get this working but I'm afraid I already put more money into it than it's worth. Any advice? My Harbor Freight spark ignition tester shows that there is a spark upon cranking.
Whimsey
Whimsey
