Originally Posted By: Cujet
Of course, I've read the same claims, in this case, it's impossible to tell. It can hit paper at 50 yards once. Then it's off the paper and I can't find where the round goes. I see the dirt plume, but the backstop is so far away, I can't tell if it's up-down-left or right.
If the rifle won't print on the paper consistently at 50 yards, something is drastically wrong. As far as shooting it with the bayonet on or off, yes, there are barrel harmonics that come into play. But certainly not enough to keep the rifle from hitting the paper at such a close range.
If everything on the rifle is tight, could it possibly be the stock applying uneven pressure? You could try relieving the barrel channel. A type of, "poor man's free float" job, if you will. These rifles were pretty much thrown together. Especially during war time. Other than that, the only thing I would suggest is slugging the land and groove diameter to see if the barrel is drastically oversize, or some other anomaly. Or else have a good look at it with a bore scope to check for any severe pitting, stripped rifling, or even a bent barrel. It's odd because most of these things shoot pretty good. Not MOA, but acceptable accuracy for a bolt action battle rifle.
