Thanks for your replies!
I am original owner of the car, wife's car. The oil has been changed regularly within the 5k miles recommendation. Valvoline semi synthetic was used since new, up to about 115k miles, when I noticed the condition. I switched to EDGE in an attempt to clean it up, maybe it is doing just that. I thought might just stop after the last change, but this one was worse than previous. The blackness definitely has to be come carbon and even if microscopic in size the particles will be hard. While the filter catches it, I really don't want it going through the pump either. The only thing I have ever seen of similar consistency is within an intake where blow-by gasses hit a hot surface. Modern engines have much hotter surfaces than the ones from 30 yrs ago.
This is a 2001 RAV4 with the standard 4 cylinder engine. Lots of runs under 15 miles, starting from room temp. It is kept in a heated garage in winter, but I think it probably takes a good 20 miles in winter to reach normal temperatures. The gage shows normal pretty quickly, but experience says the oil takes much longer.
I will add, for the past couple of years, if left sitting for a couple of days it will give some oil smoke when started and takes a good 3 minutes min to go away. Me thinks it is bad valve guide seals, but can not see how that might have produced the condition presented. The plugs don't foul, and it does not use oil between changes. Blow-by could be high even without loss of oil control, though. I'll check that.
I am thinking the 3k oil change period recommendation might just be the ticket.
Removal of the valve cover is an option that I have considered.
This RAV4 has been, until now, the most trouble free car I have ever owned. 14 VWs '62-68', '78 Volvo 242 160k, C10 260k, Sable 140k, Saturn 120k, BMW 540 155k, '88M5 155k. In order of worst: Saturn, 540, Sable, Volvo, C10 - The 540 may have been worth the trouble, but needy.
