2015 Dodge Dart 7,697 NAPA Full Synthetic 0W 20
Grand Rapids, Michigan
Code:
Time on unit 49,983 42,286 34,213 26,460
Time on oil 7,697 8,073 7,753 7,840
SAE 0W 20 Napa VAL VAL PZ
Type FS SP DP PLT
Metals
Iron 9 10 14 11
Chromium
Lead
Copper 2 5 5 8
Tin
Aluminum 4 6 8 7
Nickel
Sliver
Titanium
Vanadium
Contaminants
Silicon 15 15 18 19
Sodium 352 339 352 21
Potassium 11 30 12 13
Additives
Magnesium 10 10 10 8
Calcium 2014 2133 2305 2226
Barium
Phosphorus 658 614 658 648
Zinc 749 721 749 762
Molybdenum
Boron
Contaminants
Water
Coolant No No No No
Physical Tests
Viscosity 7.4 9.0 7.5 9.0
Physical/Chemical
Base Number 3.6 3.7 3.0 4.3
No reason not to continue using NAPA Syn........looks great! TBN of 3.6 after nearly 7,700 makes me feel like my 7,500-mile interval it too short.
Yes if you look at the VAL DP, that's the Valvoline Daily Protection Full Synthetic that was sold at Meijer stores for only a few months, I believe it could have been Napa Full Synthetic in a different label.
TOTO.
I would assume this Napa FS is the older blend based on the high sodium and calcium and not the new Dexos 2 blend?
Yes your assumtion is correct this is the older blend of NAPA Full Synthetic Oil.
TOTO.
