Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
103 registered members (380SLbenz, 1WildPig, 2012AccentSE, aircooled, ABerns, 2K2AcuraTL, 9 invisible), 2,159 guests, and 141 spiders.
Topics286,197
Posts4,904,022
Members67,576
Most Online2,967
Mar 10th, 2019
Husq 322L, how to convert to brush cutter? #4738142
04/25/18 08:37 AM
04/25/18 08:37 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
What do I need to convert to a bladed cutter? A left hand nut and an arbor.? Please advise. Thank you.
Thick oil is better grin2
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4738175
04/25/18 09:09 AM
04/25/18 09:09 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Is the 322 heavy enough for a brush cutter?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Husq 322L, how to convert to brush cutter? [Re: CT8] #4738203
04/25/18 09:37 AM
04/25/18 09:37 AM
wv
krismoriah72 Offline
wv
Blade Locknut, Support Flange, Support Cup
http://www.baileysonline.com/Parts/Parts...s-537048502.axd
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4738216
04/25/18 09:54 AM
04/25/18 09:54 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Thank you Krismoriah 72
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4738625
04/25/18 04:18 PM
04/25/18 04:18 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I used to buy stuff from Bailey's before a Stihl place opened in town.
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4739023
04/25/18 09:38 PM
04/25/18 09:38 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
It isnít the best idea to put metal blades on loop handle trimmers.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4740506
04/27/18 12:09 PM
04/27/18 12:09 PM
NJ
JLawrence08648 Offline
NJ
You'd be surprised how much power a blade uses. Make sure that it is a option for your machine otherwise it will bog down bad and useless.
Re: Husq 322L, how to convert to brush cutter? [Re: JLawrence08648] #4740903
04/27/18 07:41 PM
04/27/18 07:41 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Quite the opposite in my expirience. The blade uses less power than lines. You have a tendency to bog it down cutting off more than it can chew due to blades not flexing out of the way when you take to big of a bite. I have to richen the carb a little to keep the rpms down when I go to poly blades verses line.
2014 Toyota Sienna
1983 Chevy K5 350
Re: Husq 322L, how to convert to brush cutter? [Re: andyd] #4754123
05/11/18 11:25 AM
05/11/18 11:25 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I went with the Husqavarna accessory from Baileys. The manual was printed in 15 languages. I just wish it included the screw dimensions, It came with a shoulder strap and wing handle to add to the loop. Cuts briers and bigger weeds easily. Of course, the Husqvarna resisted the mod. I flooded it and after I put a new plug in, the starter wouldn't rewind. Once I figured out it was a stuck pawl in the starter cup, It was easy to fix. Mostly, it needed to be cleaned. I held the pawl retracted with a piece of fine wire and all was good. Wrestling with that involved the tank and one of the fuel line grommets sprung a leak. So I will try to replace them tomorrow. I need to mix more fuel before I can give it a work out.
