Anyone tare their motor down after a maintenance schedule with long oil change intervals? I get that oils have good add packs and will last longer but does the extended drain end up with more sludge? Looks like 5000 miles would be long enough to not be waistful but short enough to keep your motor clean. I'm no engineer or lube specialists so educate if you will.
