Amsoil EAO 80 Cut Open (26500 miles)
Why didn't you get the big one?
Any pictures of it before you tore into the endcaps?
Looks good. Thanks for the C&P.
Originally Posted By: paulri
Do you know how many months/years the EA was in use?
It was in service 2.5 years, next cycle will be 30,000 miles. As it’s used with a bypass filter there should be no problem 30000 miles. 😀 Annual oil sampling to see how the oil is holding up.
Originally Posted By: A310
Latest report on this oil with 57,543Kms. Since the last report I changed 2 MotorGuard rolls, one full flow filter and added a pint of Schaeffer Moly EP. Not sure why the raise in Aluminum, possibly the results of adding the Moly but will keep an eye on it.
Kinda looks like a Purolator Boss. The boss has similar spiral louvers, mesh backing, metal end caps.
