Originally Posted By: KrisZ
This is for weight reduction and it is a cutaway. I don't see it being a passageways.
The article mentions using those passageways for cooling, in a spot or two.
Quote:
Honeycomb lattice can make 3D-printed gasoline piston lightweight and strong, while integrating cooling channel near crown.
Quote:
...with 3D printing, a piston can be created one layer at a time through additive manufacturing, and a super-strong honeycomb lattice can replace the solid material, reducing mass about 25% while also optimizing the cooling of critical areas, reducing friction and parasitic losses and improving material properties 75% compared with traditional pistons.
Guessing they might have to pump oil up the rod in order to have full effect? I'm not sure how much they can scrape off the cylinder walls (which would be warm already).
