My wife often uses my car for her business travels and she was coming home for the weekend on Friday from Fort Wayne, Indiana
when the check engine light came on and the car lost a lot of power.
The GTI has 126K on it. The engine is turbo direct injected.
She pulled into a gas station in Wapakoneta, got a hold of me at work.
I had her plug the bluetooth code reader in I keep in the center console, sync it to her phone and she texted back OBD code P0087.
I left work, did some quick Youtube/internet research and crossed my fingers the high pressure fuel pump went bad.
My car has two fuel pumps, one in the gas tank and one on the engine.
It apparently will run on the low pressure fuel pump in the gas tank, but at a huge reduction in power and it overworks that pump.
A local VW dealer had a fuel pump in stock. The fuel pump was revised by VW and I got the newest version for $286.
It took about 25 minutes to replace. Very easy job.
I inspected the roller lifter and it looked great. The previous generation GTI used a wear prone flat tappet to drive the fuel pump.
It took me 3 hours and 20 minutes to get up to her which sucked for both of us. But I fixed it and the car runs great.
