General RT43 or Conti TrueContact Tour
by Propflux01 - 12/13/19 10:16 PM
Mobil 1 0W-40, 2820 Miles, 2000 Mercedes E55 AMG
by Fotoflame - 12/13/19 09:48 PM
Streaming question
by loneryder - 12/13/19 09:43 PM
Anyone use 75w-85 instead of 75w-90
by jqgz - 12/13/19 09:42 PM
Cooper Discoverer AT3 4S - Thumbs Up!
by Nick1994 - 12/13/19 09:24 PM
Vortex 6.0 water pump
by chilson450 - 12/13/19 08:51 PM
Transmission fluid dilemma, need advice
by Sumo91 - 12/13/19 08:49 PM
Should I replace the Sonata?
by Nick1994 - 12/13/19 08:20 PM
Best P185/65R15 on the market? (+Low RR)
by Vern_in_IL - 12/13/19 08:17 PM
15 focus oil choice
by gabriel9766 - 12/13/19 07:58 PM
Building Up a New Stash
by Mr_Luke - 12/13/19 07:19 PM
acdelco DEXOS2 made by
by jkhawaii - 12/13/19 06:54 PM
UOA Corvette Z06 LS7
by randomhero439 - 12/13/19 05:34 PM
CCA va Reserve Capacity
by Gebo - 12/13/19 04:51 PM
Key fob 3v
by Duffyjr - 12/13/19 04:47 PM
car fax Diy uploads
by WhyMe - 12/13/19 04:43 PM
Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count
by thescreensavers - 12/13/19 04:34 PM
Penrite base oils
by KiwiBiker - 12/13/19 04:31 PM
chadder1313, Sumo91, CleanSump, Phillip0web, puppykat33
70121 Registered Users
87 registered members (92saturnsl2, 928, 14Accent, 379KITTY, Astro14, 5 invisible), 1,432 guests, and 29 spiders.
Topics298,783
Posts5,140,974
Members70,121
Most Online3,589
Nov 2nd, 2019
03' 2.3 Ford Focus / Dash light on steadly #4735643 04/22/18 07:47 PM
O
Oregoonian Offline OP
O
Just recently, the engine dash light turned on, and is on steadily . Per manual....it indicates some issue with emissions.
Before I take it to a mechanic, is there some way (without cost) to determine what the issue could be. Vehicle has 146 K on the OD.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4735647 04/22/18 07:50 PM
spasm3 Offline
If there is an autozone parts store near you, they check cel codes for no cost. Its a starting place. Just reseach the codes. Do not let them start selling you parts, until you do your homework.
Some parts are ok aftermarket. Some things like egr solenoids, tps etc are better from OEM.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4739813 04/26/18 04:22 PM
O
O
A relative told me he recently had the same issue (Engine Dash Light) on. He decided before doing any expensive work on the emissions system....he would just changes out the fuel filter.
Since that is a fairly cheap thing to do....I did it. (I had previously changed the fuel filter out about 50K ago). Low and behold it worked...and cost me very little to do. NO MORE ENGINE DASH LITE ON). Vehicle runs nice and smooth again.
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4741132 04/28/18 12:46 AM
T
tbm3fan Offline
T
You're next issue that should come up soon will be a crack in the pcv hose behind the intake manifold. I've already had to change mine out. Several hours to do so best to change valve also.
2018 Mazda 3
2004 Buick LeSabre
2004 Focus
1998 Sable
1991 Mazda 626
1973 Polara
1968 Cougar
1968 Mustang
1967 Park Lane
1965 F-100
My toy: USS Hornet CV-12
Re: 03' 2.3 Ford Focus / Dash light on steadly [Re: Oregoonian] #4741141 04/28/18 01:23 AM
O
Olas Offline
O
If you have a cheap reader, plug it in.
If you have a can of deodorant of other flammable aerosol, spray it around the engine and listen for changing rpm.
Cable ties should hold it
