Oil shear and 0w,5w,10w?
MA.
Looking at different UOA and in cases that the oil shears down a grade or more the comments are usually "Your oil went from a 30 weight to a 20 weight." So the question I have is what happens to the first number like it was a 10w30 so now is it a 5w20 or a 0w20? How much does the first number change?
Seems like it's generally worse at higher temps, so it would be a decrease in the 2nd number. The viscosity improvers get sheared by bearings & timing chains, therefore the hot viscosity starts resembling the low W number, i.e. your 10W30 gradually becomes a 10W20.
Originally Posted By: Camprunner
... How much does the first number change?
Not much, I suspect, because it depends mainly on low-temperature properties of the base oil, which isn't affected by the shearing of VI improvers.
FWIR, the current API standard allows any 0W to slip to a 5W in service.
It isn't the base oil alone that determines the winter qualification of an oil.
Same true with 5w slipping to a 10w in use. And a 10w slipping to a 15w and so on correct Shannow?? I think that is correct.
Poor point depressants are large molecules iirc, they surely shear as the vii do. One thing for sure, oxidative thickening will play a role.
So? Camprunner's question had to do with shearing, not oxiditive thickening.
You're correct that PPDs are large polymeric molecules (usually Poly-Methacrylates) but they generally DON'T shear down. They typically have a lower molecular weight than VIIs and would classify as zero SSI on the Bosch KO30 shear rig. I only know this because several years ago I was looking for a PPD which WAS easily shearable and most disappointed to discover they didn't!
Thanks for sharing that.
While the 2nd number is based on KV100, which is generally achieved with Viscosity Index Improvers, the first number is based on CCS and MRV performance, which is achieved via base oil selection and viscosity as well as Pour Point Depressants.
So, when an oil is in service, you have a few things going on, which include, but are not limited to:
- Oxidation
- Shearing
- Contaminant suspension
The first two run contrary to each other. That is, while the mechanical action of engine components on the VII's works to break them and reduce viscosity, as the oil oxidizes, it thickens. Generally, we only see that on longer run UOA's on here, which means we don't see it frequently
The last one also can lead to thickening, but it depends on what the contaminants we are discussing are. Fuel is a contaminant, that gets into the oil that thins it out, reduces its flashpoint and may actually aide in cold temperature performance, whilst carbon particulate and other contaminants will make it thicker.
As Shannow mentioned, an oil is allowed to slip a W rating in service, so the W number generally heads the opposite direction of the KV100 number. So you have your multi-grade working to head for straight-weight territory.
Now, certain base oils have better natural VI's than others. A PAO can do 5w-20 or 10w-30, perhaps even a 0w-20. And shear is not the only cause of viscosity loss as I touched on earlier. Often what is ascribed to shear on here ignores the flashpoint, which will point to fuel being a player as well. A PAO-based synthetic will not need the volume of PPD's (due to the absence of wax) that a lesser group base will in order to achieve cold temperature performance. And this means you can start with a heavier PAO than you would say a Group II, so the latter would need more VII's to hit the KV100 target than the former.
So it depends on a number of things but if we were looking to generalize, I would say that the W rating has a loosely inverse relationship to the KV100 SAE grade in service. As the VII's shear and the fuel dilutes, the overall viscosity drops, but this is competing with oxidative and contaminant thickening which works to bring viscosity back up. The oxidized product will not have the same cold temperature performance as the original blend. So you end up with a narrower and narrower spread as time goes on. A synthetic oil will be more resistant to this phenomena, particularly one with a lot of PAO in the base blend.
This really got my attention...are you at liberty to discuss your desire for a shearable PPD?
It's ancient history now and my 'desire' is all but spent! However if you type the words 'sacrificial viscosity improver' into Google, you might just find a patent that reveals all.
Read Camprunner's post, not just the thread title.
does this mean a 0W oil can never become a 10W in order to pass API standard?
just curious, how is this "service allowance" defined and/or tested/evaluated?
so many variables here when it gets to consumer, engine type, temp, etc. ...
It's in the Standard engine tests, and the bench oxidation test that the "used" oil sample is obtained from
http://www.aftonchemical.com/Afton/media/PdfFiles/Specification_Handbook.pdf (page 33 in browser window).
In YOUR engine, YOUR OCI, and YOUR driving style, YMMV.
good doc. that should keep one busy for a while ...
my wife calls is "my porn" lol any time I'm using Wikipedia or reading technical stuff ...
I told her look there is web site all about engine oil, she goes "why?"
btw, nice job with the patent!!!
