I've never torqued the drain plug on my 7.3, due to not being able to find a torque spec, even with a new washer it has always had a slight leak from the plug. Amsoil lists the plug torque for the 6.0 and 6.4 Powerstroke as 32 ft lbs (their pans are identical from what I can tell), would I be ok using the 32 ft lbs spec on the 7.3 being the pan is similar to the 6.0 and 6.4 or does anyone know the actual spec for a 7.3?
Also I have some OEM Toyota flat washers and OEM Nissan crush washers, both for drain plugs. Most toyotas and nissans take an M12-1.25 drain plug. Just out of curiosity, can the flat washer be used on a nissan plug and the crush washer be used on the toyota plug, with no leaks?
