Halo H99IC Pot light. Takes a 120V medium screw base bulb, so no transformers involved. Using a halogen light bulb, not led. This is one in a line of five pots controlled by a Leviton SureSlide dimmer.
There is a slight delay before the bulb comes on in this one pot, the other four pots light up instantaneously. The delay can vary from one second to three seconds. Dimmer on at full strength. No flicker at all, the light turns on cleanly. No issues inside the pot, the bulb socket and the thermal protector are ok.
This pot might have quick connectors in its junction box. I have yet to go up into the very dusty attic to open up the junction box.
Any idea what the problem might be?
