Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
30 registered members (blufeb95, Duke, bourne, E365, CPA1989, 97prizm, 4 invisible), 1,255 guests, and 30 spiders.
Topics305,999
Posts5,284,427
Members71,558
Coolant Question - Can it degrade or go bad? #4704393 03/23/18 04:12 PM
M
maverickfhs Offline OP
M
I have quite a few coolants laying around, some of them are sealed and some are open.
Was wondering if can go bad after some time or have some expiration? Understand, it's NOT milk. wink
But still wanted to verify with pro's Thank you thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4704411 03/23/18 04:28 PM
Shannow Offline
I can't see them going bad in sealed unopened containers.
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4704907 03/24/18 07:01 AM
L
Linctex Offline
L
It never goes bad.
I have drained "near-new coolant" from rusty systems, let the crud settle down, and put it right back in another system.
Coolant never "wears out" - Several engine manufacturers suggest doing an analysis to see which additives are depleted (similar to a UOA) and the additives can be bought separately in small bottles to add to the coolant to replenish it.
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4704957 03/24/18 07:54 AM
T
Trav Offline
T
I read a long time ago that its the heating and cooling cycles that cause the additives to deteriorate, it sounds reasonable but I have no idea how true it is.
Re: Coolant Question - Can it degrade or go bad? [Re: Trav] #4705061 03/24/18 09:41 AM
O
Olas Offline
O
It sounds reasonable from a chemical POV but sounds like a bad choice of material for a system that is designed to see heat cycles..
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4705062 03/24/18 09:42 AM
M
M
So does it mean it'll go bad in 'opened' bottles and should be good in sealed bottles?
Thank you all.
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4705987 03/25/18 01:12 AM
N
Nyogtha Offline
N
Valvoline lists shelf life for their Zerex brand antifreeze products on their web site, in the PI sheets. I use those as my go-by, it varies from 2 years to 5 years depending on specific antifreeze type.
You could call or email Valvoline to get their viewpoint on what happens when antifreeze shelfife is exceeded.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4720914 04/08/18 08:15 PM
P
pbm Offline
P
About 6 years ago I put traditional green Zerex made in 1998 (from an unopened container in my garage) into a newly purchased (used) 2008 Hyundai Elantra. When I changed the timing belt 2 years later the water pump looked brand new.
I don't think unopened coolant deteriorates over time enough to worry about.
PS: None of the coolant had settled out in the container despite sitting all of those years....
'Journalism is Dead'
Re: Coolant Question - Can it degrade or go bad? [Re: maverickfhs] #4734159 04/21/18 12:53 PM
W
Warstud Offline
W
Yes it degrades and can go bad. The inhibitors do break down and don't protect metal as well as fresh AF. Also Coolant becomes Acidic and corrodes metal. To stay on top of the game...you can always buy test strips and check your fluid every year.
