Yamalube 10W-40 4W alternatives for Waverunner
Ontario
Have 2004 Yamaha FX HO Cruiser 160HP MR1 4 stroke engine. Originally called for 10W-30 Yamalube, then they changed it to 10W-40 Yamalube. Only every used Yamalube, but it is a bit pricey.
From what I can tell it is conventional oil, not synthetic.
Wondering if there are any alternatives out there?
Thanks
i use castrol 0w40 in an 03 fx140. my friend uses mobil1 10w40 hm, in the same ski as mine. both run great. rotella works too, the mr1 engine isnt picky with oil.
I have lots of German Castrol 0W-40 I use in my BMW car. You use this in your FX140??
I use Mobil-1 0W-40 European Formula in my Yamaha Vector snowmobile due to its higher ZDDP content, but it is not TWC-3 qualified. I assume your waverunner requires that?
Originally Posted By: 4WD
FC-W is 4 stroke … TC-W3 is two stroke in marine (small craft) oils …
Thanks 4WD.
I assume 0W-40 is not FC-W qualified?
Not likely, but I haven't looked.
Have you checked out any Wave runner type forums? I frequent TY4stroke.com for Yamaha snowmobile related things so I would assume there must be forums for Yamaha summer toys as well?
iboats.com is a great forum for boating related things and I bet they also have a section for these types of water craft as well?
