My feeling is that the debris managed to get into the lifter bores and jam the lifters from rotating in their bores causing the cam lobe to remain in the same location causing wear. Most of the lifters have this wear.
Surprisingly, the head I got from the scrap yard with 80K miles on it did NOT have these wear lines. Any theories? Remember that the engine was remanufactured 45K miles ago.
The oil was changed religiously by a fanatic and as I stated Mobil 1 5W30 was used. Could this be a sign that the engine shear used up ZDDP or do you think this is this the result of debris locking up the lifters from rotating?
Prior to 1997 before ZDDP was decreased, API service classification SH motor oils Phosphorus/Zinc levels were in the range of 1400 to 1600 PPM whereas as of Sept 2014, Mobil 1 reports the following:
Mobil 1 5W30 900PPM
Mobil 1 5W30 extended performance 900 PPM
Mobil 1 5W30 high mileage 1100 PPM
Mobil 1 10W30 900 PPM
Mobil 1 10W30 extended performance 900 PPM
Mobil 1 10W30 high mileage 1100 PPM
source:
https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide.ashx
There is no question that if I continue to use synthetic it will be one with the greatest zinc content with a PAO base and a dose of ZDDP like GM EOS.
Any thoughts would be appreciated.
If my posts here should be in their own thread, the admin is free to move this, I am sorry if this is located in the wrong thread. Thanks
Mobil 1 5W30 900PPM
source:
