While doing my oil change I noticed the belts on my 2006 G35 have cracks on the underside ribbing.
I've owned the car for 3 years and never changed the belts so they likely have some miles on them. The setup that Nissan/Infiniti uses is 1 belt for all the main accessory components and a separate belt only for the A/C. We've had Nissan products before that were picky with aftermarket belts. Not sure if this is still the case or not. Any recommendations for aftermarket belt or should I just stick with OEM?
Any tips on replacement and tensioning? Looks like there is no spring loaded tensioner and you have to loosen the bolts on the pulley and then lower the tensioner after. The service manual states to use a belt tension device to measure the belt tension.
