Every single briggs and Stratton down to the little ones for a very long time has had a pcv valve. On the flatheads it was always built into the tappet cover.
Most small engines use a check valve of some some on the crankcase breather system to try to keep the crankcase under a slight vacuum. Piston motion in conjunction with the breather/check valve keep this in operation.
