Originally Posted By: NibbanaBanana
Anyway, I don't know why this guy said the two piece flush better than the one piece. But it seems like the modern one piece designs work well from what people are saying.
For gravity feed, the ideal mechanism would use a tank mounted near the ceiling with a pipe leading to the bowl. That would allow for a lot of potential energy. These are old school, but they're still being made. The user would need to normally pull on a cord to flush, but I guess someone tall could use the lever handle.
http://barclayproducts.com/shop/toilets/victoria-high-tank-toilet/
The best flush comes from pressure-assist or a commercial flushometer. But I don't know of anyone who would install a commercial system in a house, and I'm still scared that a pressure-assist tank will detonate. However, the ones that have the biggest problems seem to be using plastic tanks. A lot of the commercial ones seem to cost about $800-1000 and use metal pressure tanks.
Quote:
https://www.flushmate.com/recall/pdf/2016-recall-announcement.pdf
Hazard: The system can burst at or near the vessel weld seam releasing stored pressure. This pressure can lift the tank lid and shatter the tank, posing impact and laceration hazards to consumers and property damage.
Description: This recall is for Series 503 Flushmate III Pressure Assist flushing systems installed inside toilet tanks that were manufactured from July 2009 through April 2011. The units are rectangular, black, two-piece vessels made of injection molded plastic. Previously recalled systems were manufactured from October 1997 through June 2009. Recalled units have a date code/serial number that is 16 characters long and is located on the label on the top of the Flushmate III. The first six numerals of the serial number are the date code. The date code range for units included in this recall in MMDDYY format is 070109 (July 1, 2009) through 043011 (April 30, 2011). The date code range for previously recalled systems in MMDDYY format was 101497 (October 14, 1997) through 063009 (June 30, 2009). Units included in this recall were sold individually and installed in toilets manufactured by American Standard, Copperfit, Crane, Ecotech, Eljer, Gerber, Kohler, Lamosa, Mancesa, Mansfield, Orion, St. Thomas, Universal Rundle, Vitra, Vitromex, Vortens and Western Pottery.
https://www.cpsc.gov/Recalls/2016/flushm...lushing-systems
