Originally Posted By: RoGuE
What would be a regular maintenance interval for putting in new grease? Every oil change (once a year for me)? I've never had to deal with greasing anything before.
Also, when I grease these up after installation, how do I know how much to put in? Until I see them swell up a little?
Lots of tie rod boots are not sealed, so when you grease them, some grease will probably come out. When you see grease come out, or if you see the rubber move from the presence of grease, stop putting in grease. Now if you have an application that has a sealed boot, like a lot of ball joints, and the boot is sealed and looks pregnant and is ready to pop, don't grease it. You will only rupture the rubber seal and allow dirt and water inside, ruining it in a short time.
