This is on my LR3, about 160k on it...running 75w90 synthetic in it. I've changed it every 70-80k ish (maybe a bit long). Last fall I changed them again and the rear diff fluid was like black. Figured it was just old and new will fix it. Fast forward to last month, I had to get an axle seal replaced and my guy noticed that the rear diff fluid was black again. He said it looked like coke. Put new fluid in it, and then this month it started leaking from the pinion seal and another axle seal again. Took it back to get it looked at, suspected a breather and he drained the fluid and it's black again. Impending diff failure? No weird noises or anything that I've noticed.
Edit: It's an open diff, no locker or limited slip.
