I've never had to deal with a faulty alternator before, so I'm hoping for some advice here.
The car is a 97 Nissan Maxima auto, CA spec. No warning dash lights (or codes - last time I checked).
I had my suspicions about something not being right, and the car has been like this for about a year.
The first symptom I noticed was whining correlated to engine rpm when there was an electrical load.
I also noticed the lights dimming and blower motor reduced output/speed at low engine rpm. Idle engine rpm in P or N is 700 rpm, but drops to about 550 in gear.
About six months ago I noticed the following: after idling in gear for a while at say a traffic light, the engine rpm would start going up to 800 rpm.
I got the idea at this point that the ECU/ECM is trying to keep the voltage stable by increasing engine rpm.
I did some measuring with a multimeter rigged to the cigarette lighter socket, got some readings, and for the convenience factor I ordered a cigarette lighter socket usb adapter with voltage display.
I monitored voltage for some time and this is what I observed:
-After starting the car, any kind of higher rpm would send voltage to 14-14.3
-Regular driving (1500 rpm to 3000 rpm) voltage is about 13.5-14
-Idle in neutral voltage is 13 or higher
-Idle in gear (550 rpm) with no electrical load voltage is 12.7 to 13
-Idle in gear (550 rpm) with electrical load and the voltage starts slowly dropping from 12.7 to 12-12.1, at which point the ECU/ECM starts raising rpm and the voltage goes to 13 or higher.
The car has no driveability problems yet, and the battery is 17 months old (Everstart Plus I believe, the one bellow the Maxx). I am also running the 24F size battery.
Changing the alternator in this car is not a breeze.
I also had 2 white smoke events about 6 months apart about 2 years ago; the smoke was from the front of the engine, where AC, alternator, serpentine belt and pulley are. I have changed the AC pulley bearing as it was noisy about 6 months ago.
A year ago, I had the alternator removed from the car while working on fixing leaks.
Please share your thoughts.
