I tried it and tufoil once back when they first came out, sure you had to turn the idle down the next day or 2 but right back up again a week later. I figured that was how long it did anything.
FF 30+ years tried ceratec because it was from a reputable company and it too is sketchy. Now nothing anymore, they don't call any of this swill snake oil for nothing.
This is important.
Quote:
Unfortunately, many chlorine additive container labels do not state, “Contains chlorine.” Technically, chlorine in its pure form is a gas, so these products dodge the issue by using chlorinated hydrocarbons, paraffins, solvents, etc. If the additive container label states, “Contains no PTFE, graphite, molybdenum disulfide or solids,” the product may likely contain chlorinated additives
All is not lost for those that still have some Motokote or other chlorine laced fluid, put it in an oil can for use as a drilling lubricant, chlorine laced oils help lubricate drill bits.
Quote:
EP additives are also sometimes used (e.g. sulphur, phosphorus or chlorine). This type of fluid has
better lubricating properties than the water-miscible ones, but has less of a cooling effect. Neat oils
vary from the technically simple to some highly sophisticated formulations.
