So, I purchased the Focus in my signature back in 2015 with the intention of it being a work/commute car and nothing more. I was pleasantly surprised that a then-14-year-old car was in such good shape. I haven't been super thorough and meticulous at maintaining it, at least preventatively. It currently has 161k miles. I've repaired, so far:
The body is in fair shape but a couple door bottoms have started to rust as well as the trunk lid around the 3rd taillight. Obviously, with a 17-year old commuter car, I'm not going to fix the rust. I noticed as I was doing the brakes this past weekend that the exhaust is hanging funny toward the rear section and is probably in need of a hanger. The main motor mount has been bad since I got the car and, to my knowledge, hasn't been affecting anything but NVH inside the cabin. Also, there's some clunking in the front end that I believeis the end links but the boots are torn on the lower ball joints also.
So my question is this... how do you all determine when to pursue a problem and when to let it ride? I like this car and would like to continue driving it for a while. Should something happen to this one I would likely buy another '01 - '07 Focus, I like it that much. I just have trouble prioritizing repairs and, as I'm sure many are familiar, my wife doesn't like us spending money on something that's not broken.
I also have a bit of a bad mark on my record. I had a 2005 Dodge Neon that I'd owned since new... stopped taking care of it pretty much all-together. At 180k after really pressing the issue I finally replaced the OEM timing belt, I'd made the case to my wife that it would keep the car going longer and the risk of breaking the belt (interference design) was too high. All this only to have the car lose all its coolant around 205k on a trip home from NC and overheat (I pushed for one more exit and the car ended up melting rings or some awful catastrophic failure).
- Plugs, wires, coil-pack and pigtail
- Valve cover gasket
- Serpentine belt and tensioner
- New tires
- Tie rod ends and alignment
- Blower Motor resistor
- Front pads and rotors
- Sway bar endlinks (haven't installed yet)
