What are people's preference for those small, hand-operated pumps that are used for extracting oils or fluids from bottles such as gear oil ? There's the type that screws on to the bottle's threads and you pump like a soap or lotion dispenser or the other type that's similar to a bike air pump where the fluid is 'sucked' out of the bottle and then either pushed (or gravity-fed) out the other end.
Threads onto bottles
Gear oil pump
Gear oil pump
