Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
94 registered members (69GTX, andyd, aquariuscsm, 2019StingrayZ51, badtlc, 10 invisible), 2,192 guests, and 47 spiders.
Topics296,781
Posts4,958,818
Members66,969
Most Online2,577
Jan 14th, 2019
3M brake lube? #4729674
04/17/18 07:32 AM
04/17/18 07:32 AM
Canada
johnnyh55 Offline OP
Canada
I was preparing to do a brake job and read all the threads about brake lube discussions. From what I gather Sil-Glyde is pretty much the best for the slide pins but it is hard to find in my area, so I was thinking of using 3M Silicone paste for the slider pins since it as good as Sil-Glyde?
As for the metal to metal contact points, should I use a type of Moly grease or will the 3M brake lube(copper anti-seize) do the job?
Re: 3M brake lube? [Re: johnnyh55] #4729711
04/17/18 08:18 AM
04/17/18 08:18 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
IMO YES, the 3M is as good as the Sil-Glyde and I've used both. I use the Sil-Glyde or 3M on the slider pins and touch points but, I use anything cheaper on the backing plates of the pads to reduce/eliminate squeal.
The only parts that I use antiseeze/neverseeze on is the threads of bolts/hold down bolts.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 3M brake lube? [Re: johnnyh55] #4729716
04/17/18 08:21 AM
04/17/18 08:21 AM
Slovenia EU
Kamele0N Online sick
Kamele0N  Online Sick
Slovenia EU
Anything "petrochemical" will swell rubber (dust boots...that rubber on slyding pin etc)
I bet you have a volvo dealer in your area...PN is on a tube wink
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: 3M brake lube? [Re: Kamele0N] #4729751
04/17/18 08:57 AM
04/17/18 08:57 AM
MI
doitmyself Offline
doitmyself  Offline
MI
If that is true, then how do tie rod and ball joint boots do well with petrochemical greases?
EDIT: johnnyh55, both SilGlyde and the 3M silicone brake grease are highly regarded here. Silglyde is a castor oil grease with only a trace of silicone content. The 3M product is a true silicone grease. Comparing both under the faucet, real silicone seems to be more resistant to water absorption.
For exterior metal to metal contact points, I prefer either Dow/Honda Molykote77 or Pastelub for their very high moly content and superior water washoff resistance. Just my preference.
Regarding petrochemical greases on brakes, I believe the real concern is getting it into the inner workings of the brake system. I'm going to take a wild guess that the exterior brake bushings and tie rod rubber are both made of EPDM rubber (I might be wrong). Regardless, some here have reported that certain car brands have brake rubber that is extremely sensitive to swelling even with so-called rubber safe brake greases. It's somewhat mind boggling.
Re: 3M brake lube? [Re: doitmyself] #4729760
04/17/18 09:06 AM
04/17/18 09:06 AM
Canada
Canada
I think it depends on the type of rubber? The same reason why some lube that aren't silicone work fine on the slide pins and some cause the rubber to swell but that is only my guess.
Re: 3M brake lube? [Re: doitmyself] #4729797
04/17/18 09:59 AM
04/17/18 09:59 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Virgin rubber alone is almost never used in automobile manufacturing anymore, they are all rubber compounds eg brake parts rubber is EPDM the same a most modern coolant hoses and some weather seals. It does not play well with petroleum based oils and grease.
The compound used in tie rod and ball joints is usually today a poly/rubber mix, Buna N/NBR/Acrylonitrile is also very common but prone to cracking and deterioration and has very poor resistance to brake fluid.
3M and other silicone and castor based grease are great for brake rubber parts.
Re: 3M brake lube? [Re: johnnyh55] #4729817
04/17/18 10:26 AM
04/17/18 10:26 AM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
Silglyde and 3M Brake Lube are both readily available through Amazon.
And probably several other online retailers if the big A isnt your thing.
Silglyde linky
3M Brake Lube linky
2001 Mitsubishi Galant 2.4 - 160k+
Grandma's creampuff...
Re: 3M brake lube? [Re: johnnyh55] #4729876
04/17/18 11:43 AM
04/17/18 11:43 AM
California
nthach Online content
nthach  Online Content
California
3M Silicone paste is also stated by the OEMs as a replacement for their pin lubes - except in Toyota's case since they want a "lithium soap glycol grease" for their pins and boots. It's been used with success on Toyotas as well. I think you really can't go wrong with 3M Silicone/Dow 111/Sil-Glyde if the OEM doesn't call for a specific product and even so, you'll be fine. I've use Sil-Glyde on Toyota slide pins and bushings without consequence.
I know Honda says using the 3M paste is A-OK for their slide pins and boots.
As for the copper paste/anti-seize, it's OEM specified for drum brakes and I think Subaru says it's an acceptable substitute for Molykote M7439 paste. I use Loctite C5-A instead. I personally prefer Permatex's High-Temp Silicone Formula disc brake lube or Molykote M77 for sliding surfaces than copper-based anti-seize. Ahthough this time on a friend's Subaru, I used C5-A on the support clips.
Re: 3M brake lube? [Re: Char Baby] #4730691
04/18/18 06:27 AM
04/18/18 06:27 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Originally Posted By: Char Baby
IMO YES, the 3M is as good as the Sil-Glyde and I've used both. I use the Sil-Glyde or 3M on the slider pins and touch points but, I use "anything cheaper" on the backing plates of the pads to reduce/eliminate squeal.
I failed to mention that I do use silicone brake lubes as they don't attack rubber parts. However when I stated to use "anything cheaper", I still meant to use a lesser expensive silicone paste such as Permatex or CRC. Often I can get a 20-32 oz tub of CRC(on sale) for le$$ per oz than the Sil-Glyde or 3M. And I do like the S-G or 3M for slider pins and the le$$er costly lubes for pad backing plates to help in reducing any noises.
"Retired"
'15 Honda Civic LX
Re: 3M brake lube? [Re: johnnyh55] #4730941
04/18/18 11:09 AM
04/18/18 11:09 AM
Canada
Canada
Well I just stopped by my local NAPA and they don't carry Sil-Glyde around here. Their biggest seller is Kleen-Flo EZE-Glide. How can you tell if a lube is good or not by looking at the MSDS sheet?
http://www.kleenflo.com/msds/331.pdf
What should I look for?
Re: 3M brake lube? [Re: johnnyh55] #4730967
04/18/18 11:31 AM
04/18/18 11:31 AM
California
California
You can't really from an SDS. I know the evil Permatex green/lavender synthetic brake lube has its ingredients hidden on the SDS as a trade secret but it's bad for rubber.
The Kleen-Flo is silicone based and I don't see petroleum products on the SDS(which are required to be listed) but it's a translucent paste. I think you'll be OK.
They do make a ceramic lube - but from the looks of it per the SDS, it's a clone of the Permatex purple stuff. Stay away.
Re: 3M brake lube? [Re: johnnyh55] #4731376
04/18/18 06:47 PM
04/18/18 06:47 PM
MI
doitmyself Offline
doitmyself  Offline
MI
First, thanks Trav for correcting my mistakes about the use of EPDM rubber on vehicle parts.
This older msds for the Kleen-Flo silicone product shows it to contain 10 - 30% silicone: http://www.monarchoil.com/pdf/KF331.pdf . It's interesting (to me) that the Kleen-Flo EZE Slide has polypropylene glycol like SilGlyde.
Re: 3M brake lube? [Re: johnnyh55] #4731462
04/18/18 08:01 PM
04/18/18 08:01 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I've seen it at Autozone.
Re: 3M brake lube? [Re: Warstud] #4731704
04/19/18 06:10 AM
04/19/18 06:10 AM
Canada
Canada
Ya but I am in Canada so no Autozone unfortunetaly, I will need to pick some up next time I am in the US. I am just trying to find a good alternative for now.
Re: 3M brake lube? [Re: Trav] #4732662
04/20/18 01:05 AM
04/20/18 01:05 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
So maybe they don't "do well with petrochemical greases"?
I've raised the question of rubber compatability of greases used with tie rods, ball joints and CV boots a few times, speculating that lack of it may be a reason for failure, but never had a response.
Hello darkness my old friend....
