Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L #4729423
04/16/18 10:25 PM
04/16/18 10:25 PM
Seattle-ish
OldPainless Offline OP
Seattle-ish
2002 Tacoma V6, recently supercharged and tuned with correct fuel mods.
UOA initially showed slightly high Fe and Al, we assumed it was wear-in and it would all wash out.
The latest UOA indicates even higher wear. I am planning on reduced OCI and looking into a friction modifier like Motorkote.
Thoughts?
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729427
04/16/18 10:28 PM
04/16/18 10:28 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I guess so that Iron is out of site. The Silicon is unbelievable what kind of air filter are you using?
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729436
04/16/18 10:36 PM
04/16/18 10:36 PM
Texas
4WD Offline
4WD  Offline
Texas
Supercharged it with 150k? How would you describe how its been driven?
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729443
04/16/18 10:42 PM
04/16/18 10:42 PM
PimTac Offline
PimTac  Offline
I will guess you have a intake leak somewhere or a insufficient air filter.
Cannot see signatures any longer so it doesn’t matter.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729457
04/16/18 11:05 PM
04/16/18 11:05 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Perhaps a move a move to 15w40 may be appropriate with the supecharger installed? There would be higher cylinder pressures involved with higher connecting rod and crankshaft loads.
If you want the job done right......do it yourself.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729458
04/16/18 11:08 PM
04/16/18 11:08 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Id use an xW-40 oil in this application. Give M1 or Castrol 0W-40 a shot. Those are high numbers for a Toyota. Stay away from additives!
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729460
04/16/18 11:09 PM
04/16/18 11:09 PM
CZ factory 🏭 KC KS
Marco620 Online happy
Marco620  Online Happy
CZ factory 🏭 KC KS
Stay away from Motorkote. Try Liqui Moly Ceratec or Archoil 9100. You could even try Redline Oil in 5w30 too. Try and check air filter. Get AEM Dryflow, Injen Nano, or Apexi Power Intake. No oiled filters!
15' Civic 1.8 i-vtec 221,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729469
04/16/18 11:31 PM
04/16/18 11:31 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
I wouldn't throw any additive in just yet. Stick with the Mobil 1 but try 10w30 High Mileage for a 5,000 mile OCI. It's a more stout formula without going too heavy. I think it will help. Good luck.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729486
04/17/18 12:35 AM
04/17/18 12:35 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Silicon high, fuel loaded sample. Bump up a grade for sure.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729538
04/17/18 04:31 AM
04/17/18 04:31 AM
California
CleverUserName Offline
California
I would guess this is the TRD supercharger? It would be wise to keep an eye out for extra cylinder heads on craigslist or Ebay. If you must keep it supercharged. The 5VZ is known to go through heads and the supercharger makes it even worse. I knew a guy who had a '97 tacoma, TRD supercharged since 40K and went through 4 sets of heads within 300K miles.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729574
04/17/18 06:44 AM
04/17/18 06:44 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Air intake system and fuel system requires attention and action , I suppose.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729575
04/17/18 06:44 AM
04/17/18 06:44 AM
NY
demarpaint Offline
demarpaint  Offline
NY
IIRC Trav had a similar issue with a worked Turbo engine tearing up oil and showing high wear numbers. I'd shoot him a PM if he doesn't see this thread and he can tell you what his fix was. A 5W30 PCMO didn't cut it for him either.
God Bless Our Troops
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729582
04/17/18 06:53 AM
04/17/18 06:53 AM
Indiana, USA
Smoqueed Offline
Smoqueed  Offline
Indiana, USA
Running a K&N? Would help explain the silicon. You've also got some fuel dilution in the oil. Maybe step up to an xW-40 for a stronger add pack that will tolerate the dilution. M1 0w-40 has about 1,000 PPM of zinc and phos each, a fat dose of boron, and a whole lot of calcium to help deal with the blowby. Or even a nice HDEO would do. Track down the source of silicone first though.
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729648
04/17/18 08:03 AM
04/17/18 08:03 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
You've got dirt ingestion from what the silicon number points to, and it is going up. This is causing your aluminum and iron wear most likely. I'd also step it up to a 0w-40 or 5w-40 HDEO. A 5w-30 PCMO may not be sufficient for stock engine + blower.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: M1 5W-30, 7500 miles, 2002 Toyota Tacoma 3.4L [Re: OldPainless] #4729703
04/17/18 09:10 AM
04/17/18 09:10 AM
The land of USA-made Subies!
SubieRubyRoo Offline
Hmm... I know guys like irv and a couple others always point to the M1 having higher numbers- maybe try the Pennzoil Ultra 0W40 that is spec'd for the Chryslers? Those cylinder loads are way higher than your Taco, plus you'd see if the whole M1 Fe thing has any merit.
But yes, most definitely you need to check air filtration. Go to a non-oiled fleece or paper filter and make sure there are no ingress points!
