Drive In Movies
by 53' Stude - 09/15/19 08:49 AM
Oil/Gas prices gonna go up?
by Mad_Hatter - 09/15/19 08:10 AM
Ordering parts
by tiger862 - 09/15/19 07:44 AM
Shell conventional @ Menards. $1.99
by Kruse - 09/15/19 07:33 AM
How do I update my profile?
by ernied - 09/15/19 07:07 AM
Most dangerous job ever?
by Mad_Hatter - 09/15/19 07:06 AM
04 Grand Marquis
by mrjlube - 09/15/19 07:01 AM
Engine burning oil
by Espada - 09/15/19 06:49 AM
Walmart near me do not sell havoline oil
by MetalSlug - 09/15/19 04:11 AM
Wanted: Inexpensive car
by FirstNissan - 09/15/19 02:53 AM
Do all replacement LED headlight bulbs suck?
by Nick1994 - 09/15/19 12:56 AM
5 qt Chevron Supreme 5w-30 for $12.42 @ walmart.com
by gallydif - 09/15/19 12:03 AM
how effective is spray scotchgard?
by WhyMe - 09/14/19 11:39 PM
Want opinion of disc brake pad wear
by boulderdentist - 09/14/19 11:08 PM
Mercedes’ dealer oil filter panel/board
by SlavaB - 09/14/19 11:08 PM
Mercedes damage code
by SlavaB - 09/14/19 11:00 PM
Restoring the paint on the Crown Vic
by Colt45ws - 09/14/19 10:39 PM
Hyundai Ioniq
by WhyMe - 09/14/19 10:08 PM
Grooves in windshield due to wiper blades
by dx92beater - 09/14/19 09:43 PM
KevATL, DragSGT, Gbenitez, DoctorPc, FarmerDan
69277 Registered Users
105 registered members (2015_PSD, 87sammy, 53' Stude, Amenhotep, 08z06, aleneros, 8 invisible), 1,677 guests, and 22 spiders.
Topics294,563
Posts5,062,455
Members69,277
Most Online3,532
Jul 30th, 2019
Traveller 15w-40 VOA Ford approved??? #4729168 04/16/18 06:41 PM
T
TravisR1020 Offline OP
T
I got my VOA back from blackstone. Traveller is on the Ford approved list however this test shows the phosphorus is below 1,000 ppm. Does this additive package look weak? Attached is the VOA tell me what you think.
FILE_0575.pdf
Re: Traveller 15w-40 VOA Ford approved??? [Re: TravisR1020] #4729175 04/16/18 06:48 PM
T
TheLawnRanger Offline
T
I would use it if it's SN on the starburst like most traveller oil.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Traveller 15w-40 VOA Ford approved??? [Re: TheLawnRanger] #4729178 04/16/18 06:51 PM
T
T
This is Diesel oil
Re: Traveller 15w-40 VOA Ford approved??? [Re: TravisR1020] #4729183 04/16/18 06:57 PM
T
T
Sorry Trav. What is diesel oil's ratings system? I've never used it but you never know.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Traveller 15w-40 Ford approved but the test says.. #4729184 04/16/18 06:57 PM
T
T
I bought some Traveller 15w-40 because it was on sale and on the Ford approved list but my curiosity made me buy a quart to get a sample from for a VOA. I just got the results back and it shows the Phosphorous below 1,000 ppm. It was my understanding that to be on the Ford approved list the phosphorus had to be 1,000ppm at a minimum. How does this additive package look to you guys? Your opinions?
Traveller 15w-40 VOA. FORD APPROVED?? #4729189 04/16/18 07:01 PM
T
T
Here is my VOA on Tractor Supplyís Traveller 15w-40. Itís on the Ford approved list but itís below the 1,000ppm phosphorus levels I thought Ford required. How does this additive package look to you?
Re: Traveller 15w-40 VOA Ford approved??? [Re: TheLawnRanger] #4729221 04/16/18 07:28 PM
T
T
Iím not sure about that. The current api is CK-4 if thatís what your asking.
Re: Traveller 15w-40 VOA. FORD APPROVED?? [Re: TravisR1020] #4729222 04/16/18 07:29 PM
Dyusik Offline
I would say yes, there is a margin of error for these labs, and 900+ is clearly not in the SN category of sub 800. Still holding a CJ4 badge, the 2013 sample of it at PQIA shows >1000 phos level.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 111K Frankenbrew, WIX 57173 (4 sale)
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 2k VWB 15w40, DBL7349
Re: Traveller 15w-40 Ford approved but the test says.. [Re: TravisR1020] #4729250 04/16/18 07:54 PM
P
PiperOne Offline
P
Lab variance or what landed in the bottle that day. 940 is close enough to 1000....certainly closer than the sub 800 SN requires. When I do VOA testing it never matches the PDS exactly...just close.
HDEO in Diesel Engines. No spark plugs here.
Re: Traveller 15w-40 Ford approved but the test says.. [Re: TravisR1020] #4729262 04/16/18 08:03 PM
PimTac Offline
How many threads do we need on this?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Traveller 15w-40 VOA. FORD APPROVED?? [Re: Dyusik] #4729269 04/16/18 08:10 PM
T
T
I agree, and I saw that on the PQIA website but in 2013 Traveller was blended by Warren Distribution. For a year now itís been produced by Martin Lubricants. So I can only go off of this sample.
Re: Traveller 15w-40 VOA Ford approved??? [Re: TravisR1020] #4729273 04/16/18 08:12 PM
Z
zeng Offline
Z
Not sure if website is not updated as it's with CJ4/SM specs.
Re: Traveller 15w-40 VOA Ford approved??? [Re: zeng] #4729325 04/16/18 08:45 PM
T
T
No the website is outdated. Martin Lubricants emailed me saying traveller has been CK-4 for a year now but they are using up old labels. My Tractor Supply is just starting to get updated labels on their oil in the store now. The new oil containers have the new Ford spec on it.
Re: Traveller 15w-40 VOA Ford approved??? [Re: TravisR1020] #4729550 04/17/18 05:30 AM
dnewton3 Offline
Global Moderator
Global Moderator
Most all production spec's have a "range" (allowed variation), typically centered around some nominal value. (example: target of 1000ppm phos +/- 5% would be 950 to 1050 ppm).
However, in this case, typical ppm limits are either the top or bottom of acceptable. (example: 1000ppm min phos).
I would say this is just a slightly weak sample; likely due to production mixing variation. Technically it should fail the Ford spec, but I'd not loose sleep over this. The next batch they mixed might have been a bit high? Who knows. There is always variation in production volumes of all products. I do NOT believe a PSD is going to grenade because the lube is down 60ppm of phos from it's rated value.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Traveller 15w-40 VOA Ford approved??? [Re: TravisR1020] #4729765 04/17/18 10:12 AM
B
BrocLuno Offline
B
+1 smile
